A couple bugs I'm seeing in 2018.3
Just posting a few issues I'm seeing in 2018.3.
1. When commiting a track and setting the option to delete the original track when done, Pro Tools gives an error that the track name already exists when you try to remove the .cm from the new track name. Have to reload the session to workaround the issue. 2. When banking to the far right of your tracks on a control surface, the edit window does not scroll to show the far right set of tracks. The edit window stops scrolling at the previous set of tracks before the last bank. So if your session has 35 tracks, the edit window will only scroll to track 32 while your control surface shows 35. I'm using a 003. Has no problem scrolling to the far left tracks. I'm using the option fill all faders when banking.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
A couple bugs | ergalthema | Pro Tools 11 | 1 | 08-18-2014 10:39 PM |
A Couple of Protools 11 "bugs" handles processed with clip gain | electroteque | Pro Tools 11 | 0 | 07-25-2014 10:45 PM |
A couple of PT8 interface bugs | meech | Pro Tools TDM Systems (Mac) | 2 | 09-05-2009 07:25 PM |
A couple of PT7 CS5 Bugs | DAS-Mike | Pro Tools TDM Systems (Mac) | 1 | 03-26-2006 11:39 AM |
