Old 09-09-2019, 03:46 PM
SBP SBP is offline
Default Multi Mono links gone when session moves DSP/NATIVE
Just found an annoying issue Ultimate 2019.06.0
I have a session with Channel strip plug in on several 5.1 AUX TRACKS.
And choose to not have the chain link selected but choose to link all channels except the .lfe (I do this by un-clicking the chain and clicking on the 5boxs next to the L.... This so I can EQ everything in the 5.0 with out touching the lfe track).... And it all works great....
but.....
When I open this session from my HD native system on a HD DSP system I need to relink the 5.0 channels on EVERY instance of the plug in. Then when I move back to the Native system for editing I need to relink the 5.0 channels on EVERY instance of the plug in.... then when I move back to the DSP system for mixing (you get the idea).... its annoying.
It would be great if it could be fixed so that the links remained when you moved from Native to DSP and back again
Bruno
Old 09-09-2019, 05:10 PM
BScout BScout is offline
Default Re: Multi Mono links gone when session moves DSP/NATIVE
There's something really broken with multi-mono plugins.
It isn't an issue of DSP to Native and back again. Even Native, save and reopen loses linking. Or DSP save and reopen loses linking.
On top of that, I can't switch to other channels (for instance from L to R or C.) It flashes for a second and then flips back to L. I used to not have this problem (often bypassing one channel for the plugin).
I tried this with Channel Strip and then started trying other plugins (like bx_digital v3.) All the multi-mono plugins are doing this.
Going to file an ASC ticket. You should too. It'll get more attention and that's the point of the "support plan" we pay for.
Old 09-09-2019, 06:38 PM
SBP SBP is offline
Case Number 03782321
Old 11-02-2019, 11:11 PM
marre marre is offline
Any news on this?
I have the same exact problem.
/martin
Pro Tools Ultimate 2019.10 HDX
S3 Dock PT Control
Mac Pro 2013 MacOS 10.14.6
Old 11-03-2019, 01:41 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
I dont use multi-mono myself, but has this problem been addressed yet?
Sent from my SM-N976V using Tapatalk
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 11-03-2019, 02:22 PM
JFreak's Avatar
JFreak JFreak is offline
Yes. This is clearly a bug
Janne
Old 03-03-2020, 07:34 PM
SBP SBP is offline
Updating this thread with info received yesterday;
Thank you for reporting this issue. We have reproduced the problem in Customer Care and have logged a bug which requires further assessment by our Product and Engineering teams. For your reference, the defect/bug number is : PT-258044
There is still no estimated time for a possible resolution but if we have an update in the near future we will pass that along to you. It is our general procedure to provide a defect number then close the case.
Old 03-10-2020, 07:07 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Are you also seeing this when all channels are linked or unlinked?
I've never experienced this, but I never link only part of the channels, only either all or none.
Old 05-31-2020, 05:49 PM
SBP SBP is offline
Many thanks for fixing this issue in PT2020.05
Cheers
Bruno
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2005 01:01 PM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
