Re: Mixer choice and the future of the DELTA 1010
no one has been able to prove that they can get it to actually work. My 2626 shows 26 I/O, but still only 18 actually work. |
Then consider me the first (which i can assure you I am not). I have two delta 1010's working great in PT8.01 (and 7.4 before that).
I would say you are the first then. There have been a lot of posts claiming this in the past, and the never actually ended up working. So you are saying you have 16 I/O with access from inside PT> Then you are THE first I'm sure.
Not THE 1st.
Tell me how to post a pic in these forums, I'll show ya the I/O for one. sheesh |
you have post it elsewhere and post a link here. I am very curious to see both delta's in the I/O section.
#16
well then if you think the I/O is curious, you're going to love seeing all 16 tracks at mixdown.
again, if you re-read my post: the driver vers is important (screw the latest delta versions), and you sync via spdif (that applies to any sync of multiple deltas). we are not talking delta LT btw...(but, I would bet even two LT's could be synced). http://www.fireworxentertainment.com...ta1010_PT8.jpg |
#17
Now you and I both are not THE first
add: in setup-hardware you will see Maudio Delta The I/O will show you 2 deltas of useable I/O |
#18
. I stand corrected. |
#19
Yep, I can't stand Fwire hardware, I'll take the PCI 1010 over them any day.
version is in the orig post. throw the wordclock cables out. |
#20
Of course you only get 18 of those channels to use. But I get 26 in Reaper and 18 in PT. I like my 2626. But like I said I'm impressed that it works. Have you used all I/o at once and checked for any phase problems. Just curious how accurate they clock together.
Delta 1010 Monitor Mixer/Patchbay Router ?? | digginin9 | Pro Tools M-Powered (Win) | 3 | 02-14-2007 05:41 PM |
Anyone using the Delta 1010? | Loudnoize Ent. | Pro Tools M-Powered (Mac) | 1 | 02-13-2006 01:18 PM |
Delta 1010 PCI | Finchy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-15-2004 10:55 AM |
delta 1010 | nelsonswilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-11-2001 03:58 PM |
delta 1010 | don't come ez | Digidesign Hardware & Software | 2 | 02-13-2001 12:53 AM |
