C|24 for broadcast mix?
My church is having a Venue D-Show installed for front of house mixing. The channels from the Venue will be fed via MADI to a ProTools HD rig in the record room. The record room is outfitted with a C|24 and this room will be used to do the live video broadcast and CD record mix.
In the past, we've always used a "real" sound board to do our broadcast and record mix with a splitter sending all the channels from the stage to FOH and record. I'm unclear how ProTools and the C|24 can be used for live remixing. Can anyone point me to tutorials or pros & cons of this sort of set up? - Jasen. |
Re: C|24 for broadcast mix?
I don't see why it wouldn't work. Are you recording multi-track? I would simply send(mult) the control room feed to send the same stereo mix(the mix you listen to) to broadcast. Or, put a post-fader send on all tracks to feed a separate pair of outputs to send to the broadcast feed(with all send faders to -0 so it mirrors the main mix, but can be adjusted if needed). Keep in mind that, if you are broadcasting video as well as audio, your buffer setting may add latency to the audio, causing it to be late in relation to the video(I don't know anything about video so I can't say if it can be delayed to match).
The FOH will have 96 channels which I'm assuming we'll feed to the Pro Tools HD - I expect not all 96 all the time, only the active ones, which is probably 20-30ish for a normal service (drums, band, vocal team, choir, a couple of pastors, track). Quote:
Thanks for the info. - Jasen. |
How to broadcast using Mbox 2 | djcreation24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-29-2011 08:46 PM |
Broadcast levels again! | yazoo | Post - Surround - Video | 32 | 11-10-2009 01:52 AM |
Appropriate Levels for Broadcast TV | Rwave | Post - Surround - Video | 3 | 03-26-2008 04:00 PM |
On broadcast levels and QC... | JRogers | Post - Surround - Video | 8 | 04-22-2005 10:26 AM |
Mixing for broadcast? | bacizone | Tips & Tricks | 2 | 06-30-2004 02:33 PM |
