so what's the secret to PT 9?
9 gigs of Ram, quad processor Mac,...4 separate HD's for streaming samples/audio/system.
Apogee Ensemble Buffer set @ 1024,...PT 9 won't run simple projects with less than a dozen audio tracks, 1 drum VI, 1 Bass VI and 3 reverb effect set as sends. Pop up ever 10 seconds,..."can't run raise buffer" type of message. it really seems like some kind of cruel joke this pro app. shame because it's cool software,.but it really makes me wonder how people deal with this. I can use either Cubase 6 or Logic 9 runnning projects way bigger than this.... so,.I know what you're thinking... "do it then" I do. If it weren't next to impossible to sell it, I would. |
Re: so what's the secret to PT 9?
10.6.7
Trillian single bass track no multi. Either BFD2/superior drummer/native instruments abbey rd drums. Any of them do this. 2 altiverbs And about 6 audio tracks Project @ 24 bit/ 44.1 About a year ago when I started using PT. I got the one time setup help This did no good, in fact, the tech had no ideas Got some help by reading here. Dropped processors to"3" and raised the setup to "99%" in proc. That helped somewhat Forgive the vague description, I'm not in the studio. For this reason. It's kept me from getting to actually USE pt 9 Rather than just troubleshoot and close it, forget it and open Logic Thx again |
You need to be 1000% sure that all of your third party plugins are compatible with the OS and Pro Tools version you are using. Check the Avid plugin compatibility chart and the manufacturers site.
This is typical behaviour of a rogue plug, even if it is being not used in a session an out of date plugin can still cause this type of behaviour.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
yes,..thanks,...weird thing is,..let's face it.
most, plugin makers test PT first because of its popularity,..I use just the mainstream ones. and they are all compatico.... waves, psp, URS, sonalksis, audioease....that's it. even though they weren't really used in the project. thank you very much guys for the input. |
Have you set up "minus one processor"?
Meaning, if you have a 4 processors - set number of RTAS processors to 3.
Macbook Pro 15" 2.66 i7, 8GB RAM / 10.11.5 / Pro Tools 12 / Komplete Ultimate / EWQLSO Gold Play Edition / Steven Slate Drums / Logic Pro / Apogee Duet |
not sure if this has been said but i've told that
"your sound libraries should be in a different drive then the one you work on and the on you write to.. " |
hello guys,..
yes only 3 processors selected,.instead of the 4 on my Mac and,..yes, I have 4 internal SATA HDs,. 1,OS drive, 2,Audio, 3, Samples 4, Samples 2 thanks again |
well this is good news,..seems that according to Waves website version 6 isn't in the compatible list. I have a bunch of Waves 6 plugins.
The waves rip off plan isn't in the budget until they work with my 64 bit hosts as well. |
and now with NO plugins in the project,...-9128 messages.
2 audio tracks, trilian and a drum VI. Are you kidding me! PT 9.05 sucks |
OK...What's the Secret Here? | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-30-2009 08:22 PM |
What I think is the secret to... | JAZZMO | Pro Tools TDM Systems (Mac) | 12 | 04-11-2006 07:12 PM |
undocumented secret? LE on D24? | Seeee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-09-2003 08:28 AM |
The Secret to Pro Sound | Dean G | Tips & Tricks | 13 | 01-19-2003 08:51 PM |
Is there some top secret new PT coming out??? | Voxvendor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-07-2002 06:37 PM |
