Old 02-29-2008, 09:14 AM
larsendiese larsendiese is offline
Default midi device not listed in setup/peripheral menu
hi,
my midi keyboard (usb EMU XBOARD 49) is not listed in the peripherals menu.
when "audio windows" in msconfig is active my key is listed but I can't work in a 48Khz sample rate
is anybody have an answer for me ???
my config is :
PT LE 7.4
MBOX 2 PRO
WINDOWS SP 2
Old 02-29-2008, 10:11 AM
77pro 77pro is offline
Default Re: midi device not listed in setup/peripheral menu
A little confusing when you use 'midi' and 'sample rate' in the same question.
What exactly isn't working for you and what are you trying to do?
003r/i7-930/LE 8.0.1 cs2 on xp
Old 03-01-2008, 12:00 PM
ooh oh ooh (you are thinking i'm a novice)
there is not confusing
problem 1 : if i want to launch a protools project at 48Khz sample rate i'm not authorized by protools
until i go to msconfig/services/ "audio windows" (not active)
problem 2 : many of projects are based on audio tracks and midi tracks ( of course it's possible to work with audio and midi tracks mr 77pro ) but if the "audio windows" is not active my midi device is not listed by the peripherals menu on protools, then if i activate the "audio windows" my device is listed but the sample rate is fixed to 44100 Khz
is my post clear ???
sorry for my frenchglish...
Old 03-03-2008, 05:19 AM
UP
Old 03-07-2008, 12:17 AM
really need help on this !!!
PT 9 setup problem..Where are the MIDI IN options in setup menu?? Blickerding Windows 0 04-06-2011 02:44 PM
Peripheral Midi Menu DragonBlight MIDI 0 03-25-2010 03:52 AM
midi machine control (slave) missing from peripheral setup GStyle Pro Tools M-Powered (Mac) 0 04-12-2008 10:44 AM
Midi problem - no INPUT DEVICE option in MIDI menu tam103 MIDI 2 01-05-2007 08:01 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
