Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 09-23-2019, 11:34 AM
Steve Garman Steve Garman is offline
Default Moving a word from one session to another
In most applications I can "copy" a spoken work in one application, close it, open another, and then paste the word in the other application where I need it. I'm trying to do that in PT 12.8, copy a spoken word, close that session, open another session where I need it and then paste the word there, but that doesn't seem to work anymore. I'm thinking it used to but I may be dreaming. Does anyone know a way you can copy and paste spoken words between different sessions in Pro tools?
Thanks,
Steve
Old 09-23-2019, 12:29 PM
Bob L's Avatar
Bob L Bob L is online now
Default Re: Moving a word from one session to another
Try this -
Isolate the word and create a whole file.
Rename the file as the word or some other name that makes sense.
Save the session and close.
Open the target session.
Import Audio from the first session.
Marginally more keystrokes than copy and paste, but it should work reliably.
Bob
"Without a song,
The day would never end..."
Old 09-23-2019, 12:48 PM
BScout BScout is offline
I don't ever remember being able to copy/paste between sessions.
Do as Bob says and consolidate that word to a new file in the edit window (one combo press) and name it. Then highlight the new file and do a reveal in Finder/Windows Explorer. Open new session, drag that file to where you want it.
For such a small task, you don't need to import audio from another session.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 09-23-2019, 01:49 PM
amagras amagras is offline
I use Import session data, just select the track where the word is and delete it after the word has been placed in the new track.
https://youtu.be/HL-YAxHcfkI
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-23-2019, 07:06 PM
I usually export the clip as a file(same sample rate/bit depth as the source session). If I know where I will send it, and I name it(so its easy to find), I will export directly to the Audio Files folder of the destination session and Import Audio from the destination-session's audio files folder(so I know the file actually IS where I want it to be)(I've been stung before with clips that should have been copied, but weren't)
Old 09-24-2019, 09:22 AM
Originally Posted by Steve Garman View Post
... I'm thinking it used to but I may be dreaming...
Nope, never could - PT clipboard is cleared when session is closed. Have to either export the file or put the 'word' on a track and then import that into your target session.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Moving a session. eddiesound macOS 0 08-31-2011 01:57 PM
moving session to another DAW eggdog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-09-2007 02:00 PM
Moving session to MAC Michael Jessen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-20-2005 01:26 PM
moving session mac to mac gclef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-25-2002 08:46 AM
Moving session from NT to Mac Camilo Orozco Pro Tools TDM Systems (Win) 6 07-07-2000 10:41 AM
