Can't save files AAE error 35 occurred. What is it?
Have a very large project I've been working on for weeks. There are several hundred gigs of space left on my recording drive but it won't auto save now, in fact if won't save at all. It shows me AAE error 35. Am I dead in the water? How do I fix this and hopefully save my project?
Thanks! |
Re: Can't save files AAE error 35 occurred. What is it?
http://avid.force.com/pkb/articles/e...ssage/en343965
And this is what it says about the error..... Error -9022 or Error -35 while attempting to process with AudioSuite plug-ins. This is a known issue in Pro Tools HD 8 (Mac OS X & Windows XP). When attempting to process a large batch of audio regions using AudioSuite plug-ins Pro Tools will error: "Unable to create a new audio file on drive.... ...because DAE error -9022 was encountered" "(Error was: Volume not found(-35)" attempting to use Pro Tools will cause error
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
For some reason it wont allow me to post the included error string... so look at the link... there doesnt appear to be a work around.... my only suggestion is to possibly start removing Audiosuite plugs or perhaps others more experienced can chime in with a fix they have used....
Can you do a Save As... into a different or new folder? In my experience this happens when a drive or directory becomes unavailable to Pro Tools for some reason. It could be that the drive has been unmounted, or permissions have changed, something like that. I'm not in front a rig at the moment to experiment, but that is what I'd try first.
I agree, I have had this problem when there is a permissions issue, although I can't remember if I got the 35 error or a different one.
A few years back I had a drive that from time to time would kick out aae35 and aae50 errors then one day went to save a session and the drive clicked once and shutdown. Turns out the bridge board (the interface board inside the drive case) had failed but the drive itself was okay. Got that board replaced and the drive's been okay. How is the drive connected to the computer - direct or through a chain of peripherals? |
Insufficient Permission error 13 on save/save as | eufemistic | macOS | 8 | 03-01-2016 02:53 PM |
Exporting MP3 files - 'Access violation occurred' | fil_mac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-13-2010 11:46 AM |
Disc Error Occurred (-120) | actualsizeaudio | Pro Tools TDM Systems (Mac) | 5 | 04-13-2003 03:01 PM |
PT LE 5.2 error 1,010 occurred | stanspon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-15-2002 02:45 PM |
Save Session copy w/audio files (invalid sample rate error) | Farmer Dave | Pro Tools TDM Systems (Mac) | 1 | 02-16-2000 04:48 PM |
