Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 12-17-2018, 12:23 AM
b mcgibney b mcgibney is offline
Default any way to better distribute the workload between the cores
So I have a 12 core cheese grater. When I run Pro tools I see that the load on the CPU is distributed to the middle CPU's and many of them seem to be hardly doing anything? Can this be fixed? Trying to milk out as much as I can out of this old but powerful machine.
cheers
Brian
2010 Mac 5,1 32 GB Ram. PT 2019.6. Mac OS 10.13.3 RME UFX and lots of noisemaking stuff
Old 12-17-2018, 12:39 AM
Default Re: any way to better distribute the workload between the cores
Is it actually causing you issues with AAE errors? If not ignore it. Watching the meters usually is not that useful.
Lots of other leading info like your sample rate, buffer size you are using would be useful to know.
If you are having AAE CPU errors then you can try -
Run at a larger IO buffer size
Run at a lower sample rate
Avoid deep chaining signal paths/lots of bus chaining/stacking of plugins. Long chains/deep bussing pushes more stuff onto fewer cores.
Avoid use of multi-channel/stereo plugins when multi-mono plugins would work. Recently discussed on DUC. This causes say both stereo track parts to be processed on the same core.
Make more use of freeze and commit
Try disabling hyper threading
—- and as always...
Make sure your system is fully optimized.
Do standard troubleshooting looking for poorly behaved plugins, and plugin denormalization effects. Especially make sure disk cache is enabled==Set to a size not “normal”. I would also disable dynamic plugin processing, and leave it disabled it causes more real hassles than it is worth.
OS X 10.8.x.... are you really running 2018 on that?
Old 12-17-2018, 01:29 AM
Emi Emi is offline
Try to turn off hyperthrrading
Use multimono plugins for stereo inserts.
Mac Mini late 2012 i5 | Mac OS Mojave 10.14 | Motu 16A | Motu 828ES | Pro Tools 2019.6 Native
Old 12-17-2018, 02:26 AM
JFreak's Avatar
JFreak JFreak is offline
Turn off hyperthreading first, it has helped a lot of people
Janne
Old 09-26-2019, 11:43 PM
How do you turn off hyper threading?
Brian
Old 09-27-2019, 06:03 AM
elicious elicious is offline
ha- two similar threads;
try this...cpu setter
ihatetyping
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores Hive Guy macOS 8 05-11-2011 12:05 AM
VI Pops & Clicks: A CPR Workload Problem? Mount Royal Pro Tools TDM Systems (Mac) 3 04-05-2008 10:00 AM
A quick question on P4 workload for the veterans? Zwan5150 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-20-2006 12:09 PM
Upgrading from 002 to HD, where to distribute $$ WannabeSQ Tips & Tricks 6 06-08-2006 02:08 PM
