Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 04-23-2018, 02:12 PM
Fellerjawel Fellerjawel is offline
Default First Instrument Bundle AIR not working
Dear, I multiple times downloaded, purchased and installed First Air instrument bundle. I can see them in Pro tools First once installed. But if I select i receive a error: cannot find plug in .
Could not complete your request because acces violation occured. unable to read location 0xFFFFFFFFFFFFFFFFFF
Truth - Because I like Pro Tools so much i am keep on trying to get this plug in working. this is my last attempt after multiple tries last weeks and weekends.
I really want to get into the full version but because this Free version is not even working... i am really worried to go full monthy.....
PLEASE!!!! help!
Old 04-23-2018, 02:34 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: First Instrument Bundle AIR not working
Hi friend , more info about your system specs would be helpful and Os too .
Are you running PT as administrator ? If no do this :
Right Click*the Pro Tools shortcut Icon on your desktop ( or where you have it )
Choose 'Properties'
Click the 'Compatibility' tab on top
Look towards the bottom of the window for*" Change this settings for all users "
'Check'*the box next to "Run this program as an administrator" at the bottom
Click 'Apply' then click 'OK'
And report back !
- Jesus Alvarado -
Keep the volume UP !
Old 04-23-2018, 02:37 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Did you purchase the bundle through the Marketplace tab in the Pro Tools window?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 04-24-2018, 06:05 AM
Hi Jesus Alvardo,
Really appreciate your help.... I just ticket the box "run as admin" this was not ticket,.. now it is.
And what to do next?
Thank man!!
Old 04-24-2018, 06:08 AM
HI 64GTOBOY,
YES first time i did but get Same error. same zip.file as at the website AVID market place. In appliciation manager it seems to be installed - but in pro tools i get these errors.
Any more ideas? thanks!
Old 04-24-2018, 07:09 AM
64GTOBOY's Avatar
try deleting the zip file and installers then perform installation directly with app mananger
Old 04-24-2018, 08:14 AM
jeam25's Avatar
Originally Posted by Fellerjawel View Post
Hi Jesus Alvardo,
Thank man!!
Hi try what gtoboy suggested . Also do a trash of the databases and preferences so PT load them fresh again .
This how to do it :
Click the Windows*Start Menu.
Click*File Explorer.
Click*This PC*in the left column.
Double-click the*C:*drive.
Open the*Users*folder.
Open your current user account name folder.
Open the*AppData*folder.
NOTE: If the AppData folder is not showing, click the*View*tab at the top of the window, then check*Hidden itemsabove*Show/hide.
AppData should now be viewable.
Open the*Roaming*folder.
Open the*Avid*folder
Open the*Pro Tools*folder
Select all files in this folder and delete them.
Restart the computer.
- Jesus Alvarado -
Old 04-25-2018, 02:06 AM
GENTS!!!!!!
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
I just checked the folder deleted ZIP only after made it administrator. I think that did the magic. I saw via your guidance the boomAAX plugin in the pro tools . Never saw that one. I started pro tools and now it WORKS
Many many thanks. Cannot find the other plug ins but at least BOOM works.
Rgds,
MANY THANKS
Old 04-30-2018, 04:33 PM
jeam25's Avatar
Great friend ! Thanks for let us know !
Sent from my SM-G950U using Tapatalk
- Jesus Alvarado -
Air Instruments bundle not working! AlexPerry Virtual Instruments 22 12-11-2018 07:40 PM
Please suggest a good Virtual Instrument bundle to buy bgeorge03 Virtual Instruments 20 09-13-2013 08:40 AM
002 Instrument inputs not working Mkain MIDI 1 03-24-2012 05:58 PM
Working with Instrument tracks with MPC in PT8 cyba Virtual Instruments 0 10-15-2011 11:47 AM
Revert to old authorizations for PT Instrument Bundle? chuck.dallas Virtual Instruments 1 02-24-2011 11:16 AM
