Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 09-05-2015, 06:58 AM
maartenl945 maartenl945 is offline
Default Xpand2 not available after installation
I installed Pro Tools First a couple of days ago but it complained about XPand 2 not being availabel as plugin.
I then discovered that XPand 2 was a separate installation so installed it via the Marketplace menu.
It now seem installed, I can see it in the application manager under Apps - Plug-Ins. However, if I create a new project from a template pro tools still complains about Xpand!2 not existing in my plug-in folder. See the attached screen shot.
What can I do ?
Regards,
Maarten
Old 09-06-2015, 03:55 AM
Default Re: Xpand2 not available after installation
Pro Tools First also complains about the Xpand plugin on startup. That it is not a valid 64 bit aax plugin.
Windows 7 SP1 X64
i7 4790K @ 4.0 GHz
240Gb SSD - 16Gb RAM
RME 9652 Audio Interface
Old 09-06-2015, 08:04 AM
DigiTechSupt's Avatar
Hi maartenl945,
You can download Xpand!2 plugins inside Pro tools|First. Just go to Marketplace>Plug-ins>Xpand!2>Install.
Best Regards,
YD
Avid Audio Tech Support
Support FAQ
Old 09-06-2015, 09:14 AM
nayiaw nayiaw is offline
Hi, I have tried to open the marketplace and find the Xpand!2 plugin but everytime it returns a 404 page(The page you are trying to access is temporarily unavailable due to a planned maintenance operation.). Please help me, thanks in advance.
My ProTools | First installed in Mac Mini Late 2012 model(upgraded to Samsung SSD). Currently there's no additional plugin installed.
Old 09-06-2015, 10:02 AM
Hi nayiaw,
Please update your billing address on your Avid account and try to download the Xpand!2 plugins again.
Best Regards,
YD
Support FAQ
Old 09-06-2015, 11:10 PM
But I already DID install xpand via the Marketplace menu. See the first screenshot. But somehow it is not seen by PTF or it was not the right version ?
Regards,
Maarten
Windows 7 SP1 X64
i7 4790K @ 4.0 GHz
Old 09-11-2015, 01:20 AM
Any ideas ? Xpand is installed, but PTF complains at startup that it is not a valid 64 aax plugin, and it is not available as plug-in in the application.
This also means that none of the templates work.
Regards,
Maarten
Windows 7 SP1 X64
i7 4790K @ 4.0 GHz
Old 09-11-2015, 08:34 AM
Hi maartenl945,
It's possible that the Xpand!2 installation encountered corrupt installation, have you tried repairing or reinstalling the plugins.
Regards,
RC
Support FAQ
Old 09-13-2015, 01:08 AM
I don't know. I just re-installed again and I'm getting this error on first startup of PTF after Xpand installation. See attachment.
Regards,
Maarten
Windows 7 SP1 X64
i7 4790K @ 4.0 GHz
Old 09-14-2015, 07:34 AM
Hi maartenl945,
I need you to trash Pro Tools preferences.
1.Go to C:\Users\*user name*\AppData\Roaming\Avid and delete the Pro Tools folder.
a. Note: If you cannot find the AppData folder, click on Organize and choose Folder and Search Options. Click on the View tab, then select Show Hidden Files and Folder. Click Apply then OK. AppData should now be visible.
2.Empty your recycling bin.
Regards,
RC
Support FAQ
Several Issues in 1: Registration, Installation, Xpand2 opultaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-29-2012 01:32 PM
Re-installation Stalls at Xpand2! CeeBeeII Pro Tools M-Powered (Win) 7 07-04-2012 02:00 PM
"XPAND2.big" Xpand2 Can't Finde The Factory Content?? toolgirl macOS 1 02-29-2012 09:04 PM
"Xpand2.big" Xpand2 closes PT10 RamenShaman macOS 3 01-03-2012 09:44 PM
Update only works on Installation...cannot perform installation on Win7 xRollinx Pro Tools M-Powered (Win) 5 02-12-2010 08:35 PM
