Greyed out tracks and regions in Edit Window
This keeps happening when I open up a song that I edited the previous night.
The tracks and regions are greyed out and can't be played. It's like they're disabled. I didn't save them that way. They were active and playable last night. How do I clear this or prevent it from happening?
Pro Tools 2018.12.0 with Duet by APOGEE M-Audio Keystation 49e iMac 27-inch - Late 2015 - 3.2GHz - Intel Core i5 32 GB 1867 MHz DDR3 macOS Mojave v10.14.2 AMD Radeon R9 M380 2048 MB |
Re: Greyed out tracks and regions in Edit Window
Are these large sessions? What session parameters are being used in the problematic sessions... 44.1/48/88.2/96 @ 16bit/24bit/32bit?
A few thoughts: Is the Task Manager showing any activity when you open those sessions? Elastic Audio enabled on some tracks?
I usually go for 48/24bit
Greyed out and can't play usually means the audio interface has changed (ie, the hardware i/o has changed so the outputs are disabled.)
What is your audio interface? do you use it for other things (other programs)? What is your system?
I got the same problem, starting a few weekas ago.
I go to the I/O setup, uncheck all bus routing, click ok, Then open I/O setup again and check the first bus routing option-click ok. Then its normal again, at least on my system. Win 10, PT 12.7 RME fireface UFX
Antelope Orion Studio 2017, UA 4-710, Presonus digimax FS, Sony DMX r100 |
Are these midi instrument tracks?
This started happening to me too. I'd work on a song one night, then the next day the midi instrument tracks were grayed out. The solution I found was to duplicate the track. The new duplicate track works and plays then delete the original grayed out one. This program is imploding.
The Kill Screens (indie rocktronica) |
Yep because other tracks are still enabled and will play. It's just the greyed out ones. I don't know what elastic audio is to enable it. I think it all comes down to not enough RAM and there doesn't seem to be an obvious way of freeing up the track. Looks like I'll have to upgrade. Cheers.
Cheers
Cheers
greyed out regions in tracks | urumita | Pro Tools TDM Systems (Mac) | 6 | 02-21-2024 05:57 PM |
No Color in the Regions in the Edit Window | lou_natic | Pro Tools 10 | 1 | 06-04-2015 10:46 PM |
Gap between edit window views and regions | synth999 | Pro Tools TDM Systems (Win) | 2 | 04-26-2011 11:26 PM |
OMF regions don't appear in Edit window | muses | Post - Surround - Video | 2 | 02-06-2011 11:08 AM |
Color coding regions in Edit window? | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2001 01:37 PM |
