Old 05-04-2018, 02:48 AM
dezst dezst is offline
Default Greyed out tracks and regions in Edit Window
This keeps happening when I open up a song that I edited the previous night.
The tracks and regions are greyed out and can't be played. It's like they're disabled. I didn't save them that way. They were active and playable last night. How do I clear this or prevent it from happening?
Pro Tools 2018.12.0 with Duet by APOGEE
M-Audio Keystation 49e
iMac 27-inch - Late 2015 - 3.2GHz - Intel Core i5
32 GB 1867 MHz DDR3
macOS Mojave v10.14.2
AMD Radeon R9 M380 2048 MB
Old 05-04-2018, 07:59 AM
sdmaas sdmaas is offline
Default Re: Greyed out tracks and regions in Edit Window
Are these large sessions? What session parameters are being used in the problematic sessions... 44.1/48/88.2/96 @ 16bit/24bit/32bit?
Old 05-04-2018, 08:34 AM
A few thoughts: Is the Task Manager showing any activity when you open those sessions? Elastic Audio enabled on some tracks?
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 05-04-2018, 03:11 PM
I usually go for 48/24bit
32 GB 1867 MHz DDR3
Old 05-04-2018, 09:14 PM
BScout BScout is offline
Greyed out and can't play usually means the audio interface has changed (ie, the hardware i/o has changed so the outputs are disabled.)
What is your audio interface? do you use it for other things (other programs)? What is your system?
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-05-2018, 03:48 AM
rossi68 rossi68 is offline
I got the same problem, starting a few weekas ago.
I go to the I/O setup, uncheck all bus routing, click ok,
Then open I/O setup again and check the first bus routing option-click ok.
Then its normal again, at least on my system.
Win 10, PT 12.7
RME fireface UFX
RME UFX Presonus digimax FS Mindprint Envoice Sony DMX r100 Lots of mics LOTS of drums
Old 05-05-2018, 12:29 PM
blkdog7 blkdog7 is offline
Are these midi instrument tracks?
This started happening to me too. I'd work on a song one night, then the next day the midi instrument tracks were grayed out. The solution I found was to duplicate the track. The new duplicate track works and plays then delete the original grayed out one.
This program is imploding.
The Kill Screens (indie rocktronica)
Old 05-08-2018, 02:58 AM
Yep because other tracks are still enabled and will play. It's just the greyed out ones. I don't know what elastic audio is to enable it. I think it all comes down to not enough RAM and there doesn't seem to be an obvious way of freeing up the track. Looks like I'll have to upgrade. Cheers.
32 GB 1867 MHz DDR3
Old 05-08-2018, 03:01 AM
Avid Pro-Tools Duet. No I don't use it for anything else. If it happens again, and I'm sure it will, I'll check that it's still using this interface. Every now and again it does change to something else in the settings without me changing it myself. And I only have the one interface.
Cheers
32 GB 1867 MHz DDR3
Old 05-08-2018, 03:04 AM
Glad it's not just me :) and that's exactly the same workaround I've been using to get out of it, so thanks for confirming. I just thought there may be something in the menu options I could use to clear it, but it doesn't look like it.
Cheers
32 GB 1867 MHz DDR3
No Color in the Regions in the Edit Window lou_natic Pro Tools 10 1 06-04-2015 11:46 PM
Gap between edit window views and regions synth999 Pro Tools TDM Systems (Win) 2 04-27-2011 12:26 AM
OMF regions don't appear in Edit window muses Post - Surround - Video 2 02-06-2011 12:08 PM
greyed out regions in tracks urumita Pro Tools TDM Systems (Mac) 5 04-22-2005 05:53 AM
Color coding regions in Edit window? nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-01-2001 02:37 PM
