Old 01-19-2016, 08:15 AM
Ben Jenssen's Avatar
Default Blending FX using Pan on a Stereo Send to 2 Mono Busses/Aux Tracks
Nothing revolutionary, but I just discovered a nice little routing technique that I think has potential, and I thought I'd share.
This will be nothing new to many of you, but myself, I never thought of it before, in my many years of mixing in PT.
The idea is simple: having a stereo send that goes to two mono busses that goes to two aux's with different FX's on them, so you can use the pan on the send to adjust the balance between the two.
One simple application would be, 1 - a short reverb on one aux, 2 - a longer reverb w/predelay on the other. Then any track with a stereo send could have its own balance between the two, easily set with the pan control on its send.
Of course, the FX's could be anything, delays, harmonizers and so on. One could be wider stereo, the other narrower.
To get this to work with two stereo FX's, there is a little detail to remember: the aux's need to be mono. (If the sends go to Bus 1-2, the aux's inputs are set to Bus1 and Bus2.) Then the plugins inserted must be able to be mono-to-stereo.
Old 01-19-2016, 08:47 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: A little send/FX trick
Nice
Daniel
Old 01-22-2016, 05:55 AM
joachim's Avatar
joachim joachim is offline
http://designingsound.org/2013/01/a-...vector-matrix/
Seems to be a similar idea.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 01-22-2016, 06:12 AM
Originally Posted by joachim View Post
Shure, same thinking, but taken to the extreme with 7.1 panning!
Experimenting a bit with my simple stereo send, I'm beginning to think that maybe simpler is better and more useful. For example: The two aux's are one bright reverb and one less bright, or one full stereo width and one narrow, making the send pan control either a simple reverb brightness or reverb stereo width control.
Old 01-24-2016, 12:03 AM
take77 take77 is offline
Cool man:)
Even though I don't have sh*# to mix, I still like reading & fantasizing about these kinds of things.
Old 01-27-2016, 06:46 AM
chrisdee's Avatar
chrisdee chrisdee is offline
When we are first talking about send/FX tricks I came over this neat reverb trick on youtube.
https://www.youtube.com/watch?v=7h3T6EcaFrY
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 01-27-2016, 07:41 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Nice Ben.
New trick to me as well ...
Takk for tips !
Old 01-27-2016, 10:38 AM
joachim's Avatar
Cool !
Old 01-27-2016, 10:57 PM
dwaynedelario dwaynedelario is offline
That MixBus guy is awesome! He's a gem in the youtube tutorial rough.
HDX2 / OS X 10.12.6 / Mac Pro 2012 40GB RAM
ProTools Ultimate 2019.6
Avid OMNI+Artist Mix
Old 01-28-2016, 01:25 PM
mbourque mbourque is offline
It's important to keep in mind that this trick is NOT mono compatible.
Matthieu Bourque
Kaïku Audio
PT Ultimate 2018.12 on macOS 10.13.3
and PT HD 12.7 on macOS 10.12
Custom build
MB: Gigabyte GA-Z170X-UD5 TH
CPU: Intel i7 6700K
RAM: G-Skill Trident Z 32 Gb
RME Fireface UFX
Mixture of Mono and Stereo busses jeremy@jjlee.com VENUE Live Sound Systems 5 12-06-2012 12:59 PM
How to split a stereo bus into 2 mono busses zenstone Tips & Tricks 3 02-16-2011 06:05 PM
mono or stereo aux busses for effects peter99 Pro Tools TDM Systems (Mac) 7 06-20-2006 06:43 PM
Mono to stereo send davetron5000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-28-2003 08:43 AM
stereo/mono send question dw Tips & Tricks 2 11-01-1999 04:11 PM
