Old 09-17-2018, 10:08 AM
dark_side dark_side is offline
Default ProTools First dont see Eleven Rack
Hello!
Got this kinda error when trying to find 11R in Setup->Eelven Rack
Assertion in "e:\ code\ 222437\ protools\ dfw\ views\ umenu.win32.cpp", line 2137.
(Use the Copy button to copy this message to the clipboard.)
Dont know what to do :|
Win10Pro 64
Old 09-17-2018, 11:55 AM
Default Re: ProTools First dont see Eleven Rack
Hi, welcome to DUC...
Do you have Pro Tools first installed on your e: drive? It needs to be on the c: drive. (You could have found that by googling your error message) and I suspect that is all that is going on here.
Now it would be nice for Avid to write software that was not so fragile, and if they can’t manage that to at least have the app check and fail with an actually useful message if it’s not installed where it needs to be.
If that is not it then much more info needed. Read “help us help you” up the top of each DUC web page and provide the type of information asked for there... including...
What computer and what exact OS
What exact Eleven Rack driver version?
Does the Eleven Rack show up as a sound device for the OS?
What is selected as the Setup>Playback Engine in Pro Tools.
There is no Setup>Eleven Rack menu in Pro Tools, what *exact* menu are you trying to use?
Old 09-17-2018, 12:09 PM
Benoni's Avatar
Benoni Benoni is offline
You have Pro Tools first installed on your e: drive? It needs to be on the c: drive. (You could have found that by googling your error message) and I suspect that is all that is going on here.
snip...
While this is true, and OP, make sure you have FIRST installed on the system drive, I too have had this error several times and I have FIRST installed on the C: drive. This happens on 2 different computers so there is something wrong in the code.
I would trash everything, run Ccleaner, and try a re-install.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Eleven Rack as an Interface W/ ProTools 12.4 SeventhSounding Eleven Rack 3 01-05-2016 08:59 PM
Protools HDX and Eleven Rack Issues [email protected] Eleven Rack 5 08-06-2014 09:09 AM
Eleven Rack, Live use, some effects dont work cjsiderionj Eleven Rack 5 04-14-2014 11:32 AM
Protools 10.1.13 and Eleven Rack Expension Jean-Luc.E macOS 1 05-09-2012 07:52 AM
Can't record from my Eleven rack into protools 10 KirbyD Eleven Rack 1 03-01-2012 08:04 AM
