MARKER problem
Hello all! I'm having a strange problem in pro tools 12 in which markers are not selecting... Meaning I'm going to click on a marker and it just doesn't select the marker. Anyone else know of this issue? Anyone know of any solutions?
Tried to ask Avid, but they told me to pay $100 for a support plan. Thank you. p |
Re: MARKER problem
Are you trying to move or delete the marker? Are you trying to start playback from that memory location?
Brian See profile page for system details |
Re: MARKER problem
Either trying to start playback from that memory selection, or selecting from one marker to another. Basically I click on the marker and the cursor does NOT move there like it should...
Re: MARKER problem
1) are you doing this from the Memory Locations Window or the Timeline ?? 2) is timeline follows edit selection on or off ?? cheers john
Re: MARKER problem
1) the timeline (top part of edit window)
2) "link timeline and edit selection" is turned ON |
Re: MARKER problem
how about a little more info .. does this happen in a Fresh Blank Session with no audio tracks .. and just a couple markers made fresh ???
Re: MARKER problem
Here's how I use my markers after I create them. Go to the Window drop down. Choose Memory Locations and you'll get a window of your markers on your session. Choose between the markers in the window and hit your spacebar.
Re: MARKER problem
To John - it happens in all sessions. Old sessions i created in PT 10 or even in blank sessions with brand new markers. It's especially confusing cause it seems to be inconsistent. But most of the time, they won't select.
To Cutlerbri - that's definitely a workaround, but I'd still prefer to figure out away to do it all in the edit. Thanks! p |
Re: MARKER problem
Re: MARKER problem
Paulhammer, I'm still confused as to how you want to use markers. You are in the Edit Window, right? You have created markers for certain events within the session, like verse 1, verse 2, bridge, solo, etc. Correct?
You've named them, and for each one there is a yellow line that runs downward through all the tracks, right? So at that point, why do you want to "select" them? Do you want to click on the marker up in the ruler? If that's the case, why have a marker? The point of creating markers is to easily access them while editing or mixing. So you bring the Memory Locations box down into your session in order to quickly place the cursor exactly at the point of a marker. It's not a "work around". Unless I'm really not following how you want to use markers.
Keyboard shortcut for jumping from marker to marker... | shotgunndunn | macOS | 1 | 11-28-2012 07:45 AM |
Warp Marker Problem | shultzee13 | Pro Tools M-Powered (Mac) | 0 | 02-07-2010 09:27 AM |
Trying to set bar/beat marker, tempo marker won't conform | maitredebas | Pro Tools M-Powered (Win) | 0 | 07-31-2009 07:31 PM |
Timeline selection end marker problem in new sessions | Blaztphemer | Pro Tools M-Powered (Win) | 0 | 06-17-2008 06:23 AM |
midi marker problem | evs | Post - Surround - Video | 0 | 09-15-2007 10:38 AM |
