Old 06-28-2012, 12:08 PM
zakco zakco is offline
Default Cut/Insert Time - workflow question
From what I can tell there is no key command available for the "cut/insert" time dialog in from the "event" menu, which IMO is a major oversight.
Basically, I want to be able to edit the timeline (during dialog editing in particular) between events, but have memory location markers retain their position relative to the clips being moved. I would like to do this without having to bring up the menu based dialog and then choose from options in a drop down menu, which IMO is a BRUTALLY inefficient way to do such a simple task.
I have a D-Command, but unfortunately this function was overlooked and not available from the softkeys as far as I can tell.
Does this fall under the domain of what "quick keys" can do?
Old 07-07-2012, 06:02 PM
Default Re: Cut/Insert Time - workflow question
Anyone?
Old 07-08-2012, 08:38 PM
flommer flommer is offline
You just need quick access to the insert time window?
According to the reference guide:
To open the last active Time Operations window:
 Choose Event > Time Operations > Time Opera- tions Window.
Press Alt+1 (Windows) or Option+1 (Mac) on the number keypad to open the Time Operations window and display the last active Time Operations window.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 07-08-2012, 11:38 PM
tonwurm's Avatar
tonwurm tonwurm is offline
yes, with quickeys you can do that
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 07-09-2012, 12:04 AM
Make your own short-cut via the system prefs (you can make your own shortcut for any of the drop down menus) or use alt-H (shift-function in the edit menu) instead. Much more convenient than cut/insert time. Select what you want to move. Hit apple-H. Punch in time. Hit enter. Done.
frank.
Old 07-09-2012, 03:53 AM
Soundtrack Soundtrack is offline
There is no key command for opening the specific Cut/Insert Time menu.
However, the workflow you are speaking about is easily done in Shuffle Mode.
Just make a selection in the edit/time ruler AND the markers ruler in the same time.
If you cut time now (Delete), the Markers will follow the edit.
To insert time, just do the same and use the key command:
Shift-Command and "E"
Grz,
Louis
Old 07-09-2012, 03:58 AM
Go to system prefs/keyboard. and make a shortcut. Enter "Insert Time..." (exact spelling of the PT menu item) as the menu item and something like ctrl-alt-I as the shortcut.
Done.
Old 07-09-2012, 05:17 AM
tamasdragon tamasdragon is offline
Be aware of that with the "shift" command your markers will stay in their original position, while with time insert/cut, you can also move your markers.
my blog:Tamas Dragon
Old 07-09-2012, 06:19 AM
To reiterate:
Old 07-10-2012, 11:56 PM
Thanks for everyones suggestions.
Originally Posted by flommer View Post
To reiterate:
This is a good start, but unfortunately, it still requires several mouse moves. The multi-function dialog box with a drop down menu and process button is a very inneficient way to do what should be a simple key command. One for cut time and one for insert time. I don't want or need to see the dialog box at all.
I'm going to experiment with the OS commands tomorrow and see if I can get it working the way I'd like...
insert time Macsearcher macOS 2 08-15-2013 06:51 PM
Insert time (bars) Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-31-2012 05:11 AM
Insert Time playlists question summit01 Pro Tools TDM Systems (Mac) 1 10-03-2009 07:41 PM
How to insert / delete time Haniel Trisna Tips & Tricks 12 09-09-2003 01:44 PM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
