Error when the Nudge dropdown is selected - Image Inside!
I was playing around with the Nudge settings and changed it to (1) bar. Now I can't change it to anything else. Every time I select it I get a big fat error.
Here is an image of the error that pops-up when I select it. Help! http://img177.imageshack.us/img177/2592/picture1mm6.png [image]http://img177.imageshack.us/img177/2592/picture1mm6.png[/image]
The Kill Screens (indie rocktronica) |
Re: Error when the Nudge dropdown is selected - Image Inside!
This is an annoying bug that has already been reported by several people but not fixed by Digidesign.
Here is a workaround until they fix it: The problem occurs if you start a new session as the Nudge value shows 0/0/005 in Bar/Beats display. The "005" is the problem. Even if yours got corrupted when you set it to an even Bar, or if it's a new session at 0/0/005, then try doing the following: -Click on the first zero in the 0/0/005 main Nudge info line so it becomes highlighted, and press the Tab key to "tab" over to the "005" column. Now manually type in some 16th value like 240 and hit Enter. You should know see 0/0/240 displayed. At this point you are fine, and you can now go back to using the "regular" dropdown menu and pick any Nudge value, and you won't get any more errors for that session. You'll have to do this for any session that shows: 0/0/005. It would be nice if Digidesign would fix this! Hope this helps, Wade |
Yes, we're aware of the problem and it is logged for a fix.
nudge inside a region | druth77 | Pro Tools TDM Systems (Mac) | 6 | 11-20-2020 01:55 PM |
Auto-bank to selected track does auto-nudge to selected track | goran m | Artist Series | 0 | 10-16-2013 08:54 PM |
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? | EricHirsch | ICON & C|24 | 1 | 08-13-2009 08:07 AM |
Error message when click on Nudge value dropdown | DiGeorge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-12-2009 06:30 AM |
Grid/nudge dropdown menu | vocalize | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-12-2002 06:47 PM |
