Old 01-04-2003, 01:44 PM
jeff caldwell71 jeff caldwell71 is offline
Default johnson j-station
I've searched & read most of the posts concerning the j-station & problems using the j-edit software utilizing the 001's midi ports. I know that almost all j-station users have had a problem with this setup, but my question is have any been able to make them (the j-station & the 001) talk to each other? All I have heard of is a workaround using a separate usb to midi converter frankly I don't want to spend even $40 bucks on one. Any info would be appreciated.
thank you [img]images/icons/smile.gif[/img]
Old 01-04-2003, 02:48 PM
da BaSsTaRd! da BaSsTaRd! is offline
Default Re: johnson j-station
check out this thread:
http://duc.digidesign.com/cgi-bin/ub...;f=32;t=012392
i love my apple iPhone!
Old 01-04-2003, 06:27 PM
neatguys neatguys is offline
The only way I got it to work was to install the original software that came with the j station first and then I used the digi 00o midi in and outs.The back panel of the jstation is very confusing as far as where to put the switch.Set it so its closest to the midi jacks.
Them go to your control panel sounds and audio devices and under audio make sure the digi001 is your midi playback device.You cant have protools open when you open the j edit software.Do you have the original j edit software?
Let me know
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Robert Johnson *tips hat* bassmanjazz Eleven Rack 3 05-10-2011 09:36 PM
OT Eric Johnson fredsparky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-06-2004 06:03 PM
johnson j-station & j-edit jeff caldwell71 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-17-2003 03:52 PM
anyone using a johnson j station w/ your digi? gabadilla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-21-2001 11:37 AM
Johnson J-Station with Digi 001 gracepoint 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-30-2001 05:26 PM
