A dream would come true if...
there would be something like NI-service center for all protools plugs
its so easy to check if you're upt o date with all your stuff |
Re: A dream would come true if...
+1
Dave Marsden UK |
+1,000,000,000,000,000,000
Many of us here have been harping on Avid/Digi for years about this one. All they would need to do is build the framework so that developers would update the version of their plugin, and provide the download link, even if it did nothing more than that, but within PT to open a window of all your plugs, and instantly see if the version the manufacturer is reporting is the same as what you have.... Shouldn't be very hard. |
Yup, this should be their next move!
Control Room: PT Ultimate HDX 2023.3.0 // Mac Pro 2012 // Mojave 10.14.6 // BlackMagic DeckLink Intensity Pro // Genelec 5 x 8250A + 7270A DSP Active Subwoofer // Yamaha NS-10's Edit Suite: PT Ultimate 2023.12.1 // Mac Pro 2013 // Monterey 12.7.3 // Focusrite 18i20 // Genelec 5 x 6010A + 5040A Active Subwoofer Video Suite: PT Ultimate 2023.12.1 // iMac Pro 2017 //Monterey 12.7.3 // Focusrite Scarlett Solo |
Unless AviDigi become the download agent for all their third party plugins it won't happen like NI service centre Chris
This is something we've been trying to implement for a long, long time, but there are serious impediments - the first being a standardized way for it to automagically update when plug-ins are updated. Currently there's no way to do that reliably - manufacturers have so many different ways of providing links, most of which require a login. I won't even get into problems when links break - imagine having to test the links to download plug-ins for all the current RTAS plug-ins that are available. The biggest problem is knowing when a plug-in is updated. Keeping track of the update messages from manufacturers, not to mention the version number of Pro Tools or the plug-in that it's for is mind-bendingly difficult. There's simply no API that does this and trying to cobble something together ad hoc has failed time and again. It's definitely not for lack of trying on our part, that's for sure. With THAT said, however, it's still something we're working on and which I'm personally involved. Currently we're looking at some voluntary work on the part of manufacturers and techs to keep things updated (and by voluntary, I mean 'additional' help, since this is far too much for a single person, especially when trying to coordinate with our testing departments and beta testers regarding actual compatibility of plug-ins). Hopefully we'll find a way to make this happen that doesn't cause more frustration with all the caveats than the typical manual process would. |
maybe AVID needs to set the standard of the acceptable compatibility take them to lunch and give them the standard... they would either get with the program or someone else would get their business. are you dealing with divas or what?
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Years ago I introduced an idea to offer new quality and support levels and distinctions for 3rd-party plug-ins. As in if a 3rd-party plug-in exercised our published strict guidelines, requirements, and passed the test cases, Avid could offer a "Golden Seal of Approval" routine. Those earning a Golden Seal approval could therefore be secured in a easier, sharper method of auto-updating, download links, or best yet "everything is always up-to-date with latest OS and PT release..." Those that didn't, er uh, "play ball and get on base" would be considered as "assumed support / use at own risk"
It was met with a warm "whose gonna do all the work?" response. Which is a valid question, which remains sticky for assorted efforts and tasks for nearly any company, Government, sports team, working nations, or modern family. No comment on that Diva thing. I agree work needs to be done here to assist our user-community. Putting in on my list (again!) :) -tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
Digi, I honestly think you're 'overthinking' this. I'm not saying that PT has to handle the installation of every new plugin version, I understand that this isn't standardized, and I don't expect that would be easy.
BUT, within PT, there must be a relatively easy way to generate a 'current plugin list with version numbers'. Since PT already knows the 'manufacturer' (it must because I can sort that way) it just shouldn't be hard to also then list the 'current' version of the plugins. Get the manufactureres to help. Set up a system whereby they can be the ones to supply you with the information you need. I can't imagine why all of them wouldn't be more than happy to drop an email to you every time they update. Then you just list that current number in your system, and PT can get online when calling up this window to display for your installed plugs, the current 'listed' version. Make that the responsibility of plugin developers. And then also a field could be 'download' think, or even a link to the companies website. I don't expect you to handle the downloads. Just help us figure out WHEN new plugs are available. The free app that the guy here wrote is a start, but I found it cumbersome and just not really what's needed. But honestly, something akin to your massively outdated and incomplete 'plugin compatibility chart'. You could even have a simple 'submit plugin' button for plugins not yet included, that would drop an email to Digi. Then someone there can simply drop an email to the developer, inviting them to submit current version numbers, and it can be added to the list. Seriously, this is just NOT that hard. It would require very minimal man-hours on your end, simply someone to enter the current version numbers into some kinda database that PT could reference, and the addition of a new 'plugin in version' window. I mean, if someone here with little or no programing experience can and has written a good start, I'm not sure why this seems impossible for PT to incorporate. And if you keep telling us time and time and time again, if nearly every response from Tech Support is 'check your plugins', then HELP us do that. When I was going through this time and time again, so many of the plugins I have aren't even ON your compatibility grid. |
Is This A Bad Dream? | DOZ | Pro Tools 10 | 8 | 10-23-2011 04:52 PM |
003 and ER it`s NOT a dream | goga | Eleven Rack | 35 | 01-28-2011 05:50 PM |
Guitar Players Dream Come True!!! | EvilElfBoy | Pro Tools TDM Systems (Mac) | 43 | 05-19-2009 07:33 PM |
Mbox -Songwriter's Dream Come True - Thanks Digi | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-01-2008 10:15 AM |
Dream Digi001 came true! | Da Gatekeepa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 04-12-2002 08:02 PM |
