Old 02-19-2014, 01:46 PM
KSwiz KSwiz is offline
Default Optical Output issues with 003 Rack
Hi all, I run PT 10.3.8 from my MacBook Pro, I use a Belkin Thunderbolt hub to connect, among other things, my FW cable, since there's no FW port on my device. I have a Black Lion Audio modded 003 Rack. I also have an Aphex 141 converter giving me 8 more channels of I/O via the optical output on the 003.
I have been running this set up happily for about a year. I recently (2 weeks?) upgraded PT to 10.3.8 from 10.3.6. All seemed fine. Have been working daily since then. Today, I had a couple of odd error messages (I should have written down the exact texts, sorry) and then, later, the channels associated with the optical I/O were not showing up in the I/O options/setup. "Default" setting doesn't get them to appear. I've restarted, checked cable connections, installed the latest 003 driver. In Hardware set up, The Optical format is selected as "ADAT". I/O set up gives me currently 10 channels, but, channels 9-10 are actually coming out analog outputs 1-2, along with the normal output of channels 1-2, I discovered.
I seem to recall that under normal conditions, you could actually see light coming out of the Optical port, a reddish glow. That is definitely not the case at present.
Old 02-19-2014, 11:57 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Optical Output issues with 003 Rack
Yeh the adat out should have a red light glowing if it working as an adat pipeline connection.
Now I don't know the 003 but is there possibly a setting in the hardware setup page to switch the adat port to operate as SP/Dif? Sp/Dif being only a stereo protocol won't show the red glow that adat pipeline has.
If the unit is plugged in as a stand alone unit (not connected to the computer) does the adat out glow?
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-20-2014, 03:43 AM
crizdee, thanks for that reply. It was pretty late last night and my brain was not ready after a long day of mixing to do the obvious: trash prefs. It's one thing I failed to do, and I seem to be up and running today, having woken up with a literal one-handed forehead slap and accompanying "D'oh!". I feel somewhat ashamed to have wasted everyone's time here....let's hope I'm not back soon, tho....as that would imply a *real* problem...have a wonderful, glitch-free day, everyone.
Old 02-20-2014, 04:06 AM
crizdee's Avatar
we've all been there!!
chris
Producer, Engineer,
www.ukmastering.com
Old 02-21-2014, 11:01 AM
This is interesting, just to note...I opened the same session where my problems first arose, with the Optical output, and had the same issue again. Nothing I could do to resolve that issue while that session was open; I could trash the prefs, and open that session, and the issue would reappear.
Other sessions, after I quit, trashed prefs, and restarted, were fine.
This particular session is the first time people sent me files that were 32 bit, 96khz. It wasn't a big session, either -- they sent me 5 tracks. I opened the session and did some overdubs, say, 4 tracks, and started to build a mix with some Aux Sends for effects, say, 3-4 of those. So we have now, a dozen or so tracks, and then it started to have the issue (I can't say exactly when, but...) I am wondering if perhaps, the brain of the 003 cannot face 32 bit 96khz sessions. I have done 24 bit 96khz sessions, no problem. Interestingly enough, when the immutable, no optical out, only ten outputs (knowing, again, that 9-10 is mapped, immutably, to analog output 1-2 in this odd case) conditions are imposed by ProTools, I am given a new option in the Hardware buffer size: 2048 samples; usually the maximum is 1024. Have you encountered similar issues? Do you think my theory has some weight?
Old 03-23-2019, 07:10 PM
The 003 can handle a 96K session fine, but the optical IO cannot work above 48K(maybe that's the issue)
Old 03-23-2019, 08:52 PM
Southsidemusic's Avatar
This is a 5yo thread from 2014 so if the gut who started posting in it again need help I suggest start a new thread!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
G5 Optical Output to 192 Optical Input Irl Sanders Pro Tools TDM Systems (Mac) 1 08-22-2005 05:38 PM
HELP!!!!!! OPTICAL OUTPUT Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-13-2002 02:49 PM
Optical Output? Gato75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-23-2002 10:20 PM
Low optical output level ! Cannabis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-05-2001 10:03 AM
