Old 09-29-2016, 01:44 PM
T-Low T-Low is offline
Default HEAT + Dynamic Plug in Processing in 12.6
i´m sorry to sound like a broken record
but there is a bug in HEAT + Dynamic Plug in Processing
i´ve tested on 12.4, 12.5 and 12.6
with Yosemite and Sierra :
Create a 96 track session at 96k / 24 bit , 64 Samples buffer
no audio files needed
Activate HEAT in POST setting
Add f.x. Avid Channel Strip , or any other plug in , to all channels
Hit Play + Stop , the CPU load stays the same ... minutes later
it never drops like it should
Deactivate all the Avid channel strips and the CPU load goes down !!!
any suggestions ?
thanks
Dynamic Plugin Processing ... Waves ? T-Low Pro Tools 12 5 08-21-2015 12:44 PM
"dynamic plugin processing" Issues PT 11.2.1 musicmixer04 Pro Tools 11 6 10-18-2014 07:08 AM
Dynamic Plug-in Processing Question quantise Pro Tools 11 1 03-13-2014 10:05 AM
Is Dynamic Plug-in Processing messing up some VI's Touchwood Studios Pro Tools 11 2 11-19-2013 03:09 PM
