Old 08-28-2002, 09:00 PM
001fran 001fran is offline
Default aux won\'t follow master fade automation
new challenge...
I'm routing the audio from midi instruments (keys and drum machine)into digi inputs 3-6 for a mixdown. Normally, the master fade at the end of the song fades EVERYTHING sent to the master outs, but for some reason, my aux tracks are ignoring the fade. Why?
I've also noticed for the first time that the 5 bus buttons above my aux tracks on the mix screen are highlighted white. Is this a new feature on 5.2 that I just haven't noticed til now, or could it be indicative of the problem I'm having above?
Old 08-29-2002, 01:05 AM
CCash CCash is offline
Default Re: aux won\'t follow master fade automation
1.) What outputs are the Aux tracks set to? They have to be same as the master fader. Check this first.
2.) Check to see if "Low Latency Monitoring" is enabled in the Options Menu.
Old 08-29-2002, 01:34 PM
thanks CCash,
I realized after the post that I was running out of the monitor jacks instead of the master out jacks. duh. I'll try to post more intelligent questions in the future.
Automation to follow events fabiolcati Getting Started 6 10-24-2013 12:29 AM
Automation does not follow edit Moviesound macOS 0 07-20-2012 04:28 AM
BUG: automation doesn´t follow Frank Kruse Post - Surround - Video 79 01-07-2012 11:59 AM
BUG : Plug automation doesn't follow tombob Pro Tools TDM Systems (Mac) 2 02-04-2011 09:08 AM
Master Fade & Master Plug Ins Kenny Gioia Tips & Tricks 10 04-17-2001 02:39 PM
