Old 01-31-2024, 09:14 AM
janefoyet janefoyet is offline
Default Adding space between MIDI notes
Hi there,
Hope all is well.
Is there a way to add equal space between several MIDI notes?
Let's say I have 10 MIDI notes, all on grid, with 1 measure in between each at the moment. If I wanted to increase the space from 1 to 3 measures, is there a way to do so that is not one by one?
Thank you.
Jane
Old 01-31-2024, 09:55 AM
tope d's Avatar
tope d tope d is offline
Default Re: Adding space between MIDI notes
Originally Posted by janefoyet View Post
Hi there,
Hope all is well.
Thank you.
Sarah
A workaround is to highlight all the notes you'd like to have space by hitting Shift+clicking the notes, extend all notes (to the right) with the standard trim tool, then split the notes (cmd+E on mac) where you'd like to have space in and trim the other way. Hope it makes sense
Let me know if you have questions
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-31-2024, 10:30 AM
The Weed's Avatar
The Weed The Weed is offline
Too bad "Space Clips" doesn't work on MIDI Notes.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-31-2024, 10:39 AM
Dizzi45Z Dizzi45Z is offline
Hi there,
Hope all is well.
Thank you.
Sarah
I have done this using the Trimmer TCE Tool. For example, consolidate your notes into one clip in the edit window. Then go to the clip and stretch it exactly the amount you want them to be spaced by. This does also lengthen out the notes, so if they need to stay the same length, just highlight them all then trim the ends of them.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 01-31-2024, 10:46 AM
Agreed.
However, you can still kind of use it this way too.
In your example, in the edit window, highlight the clip and then change your grid settings to Measures. Then go Edit-Separate Clip-On Grid. Then use Space Clips (Option-Shift-H Mac). Then type in the additional spacing (I believe it would be 2 measures in your case) and hit enter.
160 GB RAM
macOS 11.7.4
Old 02-01-2024, 02:49 AM
Hi everyone,
Thank you very much for all the ideas!
I've used the space clips function after cutting a clip for each MIDI note in the edit window, with the clip being the same size as the clip, and that way was able to easily use the tool.
Once more, thank you!
Jane
Midi notes deleting when editing and writing in notes SeventhSounding MIDI 5 01-14-2018 02:34 AM
Midi Adding Small Extra Notes! redparade Pro Tools 11 7 12-11-2015 06:01 AM
Export MIDI leaves empty space before the notes start JayB MIDI 0 10-17-2013 05:15 PM
Pro Tools 8.0.1 adding space on file exports and bounces? Ssaidvox1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-08-2010 04:00 AM
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
