Old 11-11-2022, 08:07 AM
mbcn mbcn is offline
Default Waves GUI problem after installing 2022.10
Hello everyone!
After I installed this new version, all my WAVES plugins appeared very small inside a red window of the real plug in window size.
See pics to understand better! Any help will be appreciated, thanks a lot!
Im on MBP 16 inch 2019 Catalina 10.15.7
Old 11-11-2022, 10:36 AM
TOM@METRO's Avatar
Default Re: Waves GUI problem after installing 2022.10
Graphics anomalies "especially with multiple monitors" are the main reason I uninstalled all my Waves products.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-11-2022, 02:14 PM
climber climber is offline
I run dual monitors and many waves plugins and haven't seen that issue.
what version of Waves plugs are you running?
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 11-11-2022, 04:14 PM
paul_g's Avatar
paul_g paul_g is offline
No issues here, I'm on Waves 14 platinum w/ PT 2022.10, no issues here. Catalina is a bit down rev, what version of Waves are you on? You said you just updated... did you check a compatibility chart to see if was compatible with your OS?
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 11-11-2022, 05:42 PM
off the wall's Avatar
off the wall off the wall is offline
Old version of Waves??
I use many waves V14 plugs and have never seen that with PT 2022.10 and macOS 12.6.1.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 11-13-2022, 11:42 PM
I use Waves 11, maybe that's the problem? Or maybe just updating the OS?
Thanks for your answers!
Old 11-14-2022, 02:06 AM
Farhoof's Avatar
Farhoof Farhoof is offline
This seems to be a retina/scaling issue. The plugin window size is scaled up, the waves content within the window is not.
Old 11-14-2022, 05:22 AM
huzzam huzzam is offline
yes that's likely the problem: waves 11 is not compatible with PT 2022.10
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 11-14-2022, 12:09 PM
TOM@METRO's Avatar
I was running Platinum. I run 5 monitors, 3 over the console and 2 over the MIDI station. This requires 3 graphics cards. All other Plug-ins are fine with this setup. Only Waves offers the bonus of GUI corruption.
I'm sure the vast number of users won't see this, (at least not commonly) but it does hint to a vulnerability somewhere in the code.
This has been reported to them, and they have conceded that this issue exists, but the fix would be to involved to address at the time.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
Old 11-14-2022, 07:29 PM
UP1 UP1 is offline
Hi All,
Although I am now using W11, there may be an equivalency scenario for Mac so, I thought I better chime in since something potentially similar caused my EQ (emotional intelligence quotient in this case) to tilt on my previous W10 outfit.
Long story short, look for other software on your computer that may have to do with 3D Audio or gaming software and try to prevent that from running to see if it resolves the issue. In my case, specifically stopping the Nahimic Service fixed my issue. Others with similar issues with plugins in other DAWs have indicated that they could actually run Nahimic if they uninstalled a Realtek Audio Sonic package.
Please note that I have (2) 4K monitors connected and was using a GeForce 3080 at the time.
The symptoms of my issue were characterized by the following:
1. Only some Waves V14 plugins and Sample Tank 4 would not render properly like in your screen shots. In some cases, the plugin windows would be blank or white. I could then not even close those plugins as Pro Tools would hang when I would try to close them and I would need to force quit.
2. In other cases, instantiating one of the plugins with a conflict such as Eiosis or Fabfilter would not work but only if I moved them or if I opened them in my right-hand monitor. (I typically use Edit Window left-hand Monitor, Mix Window right-hand Monitor).
If I opened them and closed them in my left-hand monitor, there was no problem. If I opened them and dragged the plugin window to the right-hand monitor over my Mix Window the plugin would not allow me to change the EQ in Fabfilter for example and Pro Tools would just hang when I would try to close it.
By luck one of the workarounds I found prior to stopping the Nahimic Service was to first instantiate a working plugin in my primary right-hand monitor and then open a problematic one in the same right hand monitor. this process impacted my workflow but at least it allowed me to open and use the plugin. However, it only worked as well as my execution and in some cases I lacked discipline. LOL
Here is an example of the impact in other DAWs:
https://forums.steinberg.net/t/plugi...7841/34?page=2
This workaround does not address the root cause but for me it was well enough to get the plugins working properly. Hope this may help you to find a similar workaround for your Mac.
All the best,
Peter
Pro Tools Studio 2022.10
X32
Gigabyte Z690 AORUS ELITE AX DDR4
Processor 12th Gen Intel(R) Core(TM) i9-12900K
Windows 11 Home Version 10.0.22000 Build 22000
Melodyne doesn't render properly after TCE Tool 2022.10 and 2022.9 Dizzi45Z Pro Tools 4 01-04-2023 02:31 PM
2022.9 and Waves broken devs1980 Pro Tools 41 10-22-2022 01:47 PM
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] Dizzi45Z Pro Tools 43 05-29-2022 03:59 AM
Installing Waves Plugins JohnnyMindin Pro Tools | Intro Discussion 3 09-19-2021 04:57 AM
Installing Waves on a new Mac simon.a.billington AAX Plug-ins 24 11-17-2014 11:33 PM
