Old 08-13-2022, 02:54 PM
Ceeze Ceeze is offline
Default Audiosuite Plugins Greyed out
I've been having an issue with this most recent 2022.7 release where the audiosuite dropdown menu will randomly grey out any available plug-ins. I've tried trashing pro tools prefs which works after restarting, but after a few hours the issue comes back. My workflow hasn't changed since the last release so I'm not sure what the reasoning could be. The issue will continue across sessions, even blank ones.
Old 08-13-2022, 04:18 PM
khoop2112 khoop2112 is offline
Default Re: Audiosuite Plugins Greyed out
Same problem here.
Old 08-13-2022, 10:05 PM
nednednerb's Avatar
nednednerb nednednerb is offline
It's been like this since 2022.4
In fact, it seems to be Monterey related to me also. Dark mode related too. When I switch Pro Tools to Light theme, I see my Audiosuite menu items okay, not greyed out.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 08-14-2022, 05:05 AM
thin ice thin ice is offline
It is the same for me on 2021.12 and if I switch the OS Dark Mode off, all returns to normal.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 08-15-2022, 09:33 AM
Sunking's Avatar
Sunking Sunking is offline
Same greyed out audiosuite plugin issue here. I have been quitting PT and reopening it to solve the issue. I don't use dark mode - next time it happens I will try switching back and forth from dark to light mode to see if that solves the issue.
Mac Studio, Monterey 12.4, Pro Tools 2022.7.0
Old 08-15-2022, 10:10 AM
Just to be clear, it was Monterey Dark Mode for me and I don't use Pro Tools Dark Mode.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 08-16-2022, 10:32 AM
The one workaround I've managed to find around this is to use the new Pro Tools Search feature and looking for the audiosuite plug-ins that way. For some reason that seems to bypass it, but obviously that only works if you know what you're looking for. Interesting to hear it's been happening for a while now.
Old 08-16-2022, 11:15 AM
Top Jimmy's Avatar
Has anyone submitted a support case reporting this issue?
James Cadwallader
Old 08-16-2022, 11:40 PM
[email protected] BMAP@musicandpost.com is offline
Found this with the update 2022.7. I am running HDX with Catalina. Found if I disable hybrid mode everything works fine.
Old 08-17-2022, 11:31 AM
Just submitted this case.
Audio handles on AudioSuite render get greyed out! Spyderrp7 Windows 2 10-23-2018 08:59 AM
SSL & API plugins greyed out nickremmert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 12-25-2010 08:02 PM
Audiosuite Process "greyed Out" remute Pro Tools M-Powered (Win) 3 09-24-2006 12:42 AM
audiosuite plugins prs24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-30-2003 02:11 AM
Audiosuite plugins in HD waves3 Pro Tools TDM Systems (Mac) 5 03-29-2002 12:27 AM
