Old 02-14-2022, 09:14 AM
Justin1524 Justin1524 is offline
Default Why can't Pro Tools import FLAC files?
Adobe Audition can.
Studio One Pro can.
I'm sure other DAWs can.
Pro Tools cannot. Why?
Justin (Proud Pro Tools Ultimate PERPETUAL license owner)
Admin
www.elevenrackpresets.com
Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD
Old 02-14-2022, 11:22 AM
Top Jimmy's Avatar
Default Re: Why can't Pro Tools import FLAC files?
1) There’s no demand for it.
2) Pro Tools would never implement a format natively that required a codec to read/write, that goes against its core philosophy. That leaves it as an import/export option only and there are already many freely available external options that can do this.
3) Open source and closed source aren’t necessarily compatible just because someone desires it to be. PT is the oldest and has the greatest entrenched legacy.
James Cadwallader
Old 02-14-2022, 11:52 AM
huzzam huzzam is offline
Jimmy, Pro Tools happily imports other formats such as mp3, m4a / aac, and even Apple Lossless, which also require codecs. Just drag and drop them in the timeline. So it doesn't really seem to be against any core philosophy to do so.
Meanwhile, I could be wrong, but I believe PT uses Quicktime for import, at least on Mac. FLAC is natively supported in recent versions of Quicktime.
I don't see any reason FLAC couldn't be supported, except that it just hasn't been enabled for import in the Quicktime library.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 02-14-2022, 02:00 PM
off the wall's Avatar
off the wall off the wall is offline
Well count at least two clients asking for it :) I've had a couple of deliveries for device sounds that spec'd FLAC. It would be great to just be able to bounce to FLAC (like mp3).
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 02-15-2022, 03:30 AM
Teej Teej is offline
Yes it's also super annoying to me. Make that three users.
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1
Old 02-15-2022, 04:21 AM
midnightrambler midnightrambler is offline
I've not needed it (yeT) but I don't see why it shouldn't be implemented, it's a no-brainer.
Old 02-15-2022, 05:07 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Pro Tools couldn't even import its own SDII format until recent versions, let alone FLAC files
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 02-16-2022, 10:34 AM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Other DAWs can do SO many more things that just make sense. Other DAWs don't throw errors during sessions and max out CPUs for no reason.
I've tried all those other DAWs and for whatever reason, it's just not the same experience as Pro Tools and I'm not comfortable.
So, I use other programs to convert files and I reload Pro Tools when it errors out and I mind my own business. Tell the client while they're standing there holding their instruments staring at me through the glass, YOU wanted to make sure I used Pro Tools.
Industry Standard - so shut it.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Last edited by WombatStudio.Org; 02-16-2022 at 10:36 AM. Reason: Wanted to use all there's in one sentence.
Old 02-16-2022, 12:13 PM
Eric Lambert's Avatar
Stephen
Fireworks! Applause! Curtains...
Honestly, there's no good excuse for PT to avoid FLAC.
Old 02-16-2022, 12:58 PM
thin ice thin ice is offline
To be fair, it was always a relatively niche format. Now with drive space not an issue, those that don’t go for mp3 can use wav anyway. There are many free converters.
Apple phased out headphone sockets, CD drives and other things to move forward. Maybe they just see it as bloating the system for a format not many use?
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Import FLAC Justin1524 Pro Tools 2018 7 05-05-2018 09:19 PM
Session with FLAC Files all Files are Offline... Popschutz Studio Pro Tools 12 10 12-06-2017 01:26 PM
Pro Tools 12.6 not copying audio files on import! = Lost files DJ Hellfire Avid Pro Mixing General Discussion 2 10-07-2016 07:27 PM
ALAC and FLAC files - Bit of opic I know! Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-27-2010 01:55 AM
Using flac files K.B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-07-2008 05:06 AM
