Old 04-16-2021, 04:59 PM
sw rec sw rec is online now
Default Re: Pro Tools Installer asking me to manually delete PT
“Also, it's not 10 minutes, it's 20 because this most recent version and the prior version which came out a few weeks ago, require the manual uninstall.”
Fair enough, but I’m not about to fret over an extra ten minutes or so. That’s just how it works now.
Old 04-16-2021, 05:33 PM
philgrab philgrab is offline
Yeah, it's not a lot of extra time but annoying.
So after reading this thread I decided to go ahead, again, to install 3.1 using the Avid Link update feature. This time I cliked on remove Protools and chose just the driver and program to remove.
After I ran that process it wanted to reboot, so I did.
The system comes back up and I notice that Avid Link indicates the new version needs to be installed. So, thinking this was just an extension of the install i.e. first part uninstall, second part install, I clicked install again. It did run a different process based on the menus that popped up. At the end it wanted to reboot again. After this the system came up and voila! 3.0 was the only thing on my computer. In summary, Avid link deleted Protools, rebooted, installed a new instance of the Program, rebooted and when I launched what I thought would be 3.1, actually 3.0 had been installed again and was the only option.
To add insult to injury, Avid Link indicated that 3.1 was available to install. Somebody is asleep at the wheel when it comes to Windows 10 installs.
Old 04-16-2021, 05:36 PM
Hmm, strange indeed. It left my 10.3.8 install alone. It certainly is not without its WTF moments these days. I NEVER use Avid Link. Uninstalled it altogether, actually. I download the installer, unzip, uninstall last version, install new version.
Old 04-16-2021, 08:18 PM
So here is the process that worked finally. Although most of the people on this thread probably figured it out.
First, I couldn't uninstall PT, Windows 10 grayed it out. So I used Avid Link and that worked. Reboot.
Then I downloaded from the Avid site. Ran the install, reboot again. 3.1 is now there. Not necessarily intuitive.
uninstall pro tools 8 manually not 10 but 8 daniel formica macOS 5 12-30-2015 07:17 AM
The installer was unable to launch the PACE system files installer - Help please buzz302 Pro Tools M-Powered (Win) 3 02-14-2012 09:05 AM
Manually installing Pro Tools User999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-06-2010 03:25 PM
How to manually authenticate plug-ins for Pro Tools LE Manish Wayz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-09-2008 04:34 PM
7.3 installer? Does "clean uninstal" delete bombfactory plgs meekz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-03-2007 08:23 PM
