Old 12-18-2015, 01:37 PM
guatamas guatamas is offline
Default Axiom Pro 61 BSOD (Solved)
Has anyone else ever experienced the Blue Screen of Death on the M-Audio Axiom Pro series keyboards? If so, what was your solution?
Last night I was fiddling around with my Axiom and I got to the zones/groups page within the edit window. There were some parameters within that sub-window and something called Keyboard Panic. Long story short after pressing a few buttons and trying to figure out what some of these options did, this in turn killed my keyboard. The first thing I noticed were all the led lights that eliminate the buttons were randomly flashing, the screen froze and the keyboard was unresponsive. I turned off the keyboard and soon after that I now have nothing but the Blue Screen of Death. I have had this keyboard for well over 5-6 years. That is a long time to have something and while I do understand that at some point things fail, I also soon found out that this keyboard is experiencing the same issues others have posted on the internet.
After some research, I have found two common solutions.
The first is to pry and solder some resisters and capacitor (forgive me for not knowing exactly the terminology is). I have absolutely no soldering experience and this solution scares me.
The second solution is the one I will attempt. It is flashing the chip and reinstalling the firmware of some sort that controls the boot up process by using a JTAG device that is directly connected to the keyboards main motherboard and using a windows based app called uVision to load a hex file containing information that erases and reinstall's this "firmware". I have ordered a Keil knockoff device on eBay which ships from Hong Kong and will likely be here in Cali in about 3-6 weeks :/
Has anyone ever tried this and succeeded?
Things I have already tried:
-Different USB ports on my Mac Keyboard->Mac
-Connecting to a USB Hub (Both a USB 2.0 and USB 3.0) keyboard->Hub->Mac
-Different USB cables
-External power supply
So far none of the above solved my issue but I am hoping some of you here on the DUC had gone through this and came out victorious like I am hoping to come out.
Old 12-19-2015, 09:16 PM
Default Re: Axiom Pro 61 BSOD
Is there a compatible Axiom Pro driver for that OS?
Aaron Mulqueen - 001 HD Native
Old 12-19-2015, 09:18 PM
No, it is a class-compliant device (No drivers needed)
Old 12-19-2015, 09:37 PM
I am not even sure what you are describing is happening here.
You are not getting a BSOD on OS X on a Mac, by definition you onloy get that on Windows. So you are getting a Mac gray screen? aka kernel panic/crash on OS X? If so what exactly is OS X reporting for that crash.. go find that crash report (under System Diagnostic Reports) in the Console.app utility and cut and paste the details here. It sounds like you are getting just an application error. No BSOD or kernel panic/crash involved.
Old 12-19-2015, 09:46 PM
Here are two links to help describe the issue I am experiencing.
You can read this:
http://community.m-audio.com/m-audio...61_blue_screen
And watch this:
https://www.youtube.com/watch?v=mIqwYbaZw28
This is what I am going to attempt once the parts come in. What I am hoping the outcome is; a revived Axiom Pro.
Old 12-19-2015, 10:27 PM
OK great. But when you start a thread talking about a "BSOD" people assume you are taking about a Windows BSOD, .. usually caused by driver bugs, hence wasting time on questions about drivers etc.
Seems like you are off and going in the right direction now.
Old 12-21-2015, 01:05 AM
OP, if a firmware flash with the latest download doesn't work and a second solution has been posted, ummm take it or leave it, cause AxiomPro is or if not EOSS. I run an Axiom P49 and it's still flagship to me too.
Old 12-21-2015, 10:03 AM
EOSS?
Old 12-21-2015, 07:12 PM
End of Software Support.
Old 12-21-2015, 07:33 PM
YYR123's Avatar
YYR123 YYR123 is offline
Works just fine as a midi keyboard however
Daniel
Bsod peter5992 Post - Surround - Video 0 11-04-2012 07:20 PM
Axiom Pro 49 and Axiom 61, Prepheral issue? udhoshi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-22-2011 03:45 PM
Pt 9 + ram = bsod? critza Windows 19 02-07-2011 03:33 PM
BSOD PT 7.4.7? New Hdd digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-06-2009 04:19 PM
BSOD!! please help cuba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-26-2004 01:12 AM
