Old 10-27-2015, 07:55 PM
SupreGlu SupreGlu is offline
Default piano roll / keyboard
so i am using a 76 key triton, the piano roll editor is off what it should be...
for example, i enter D6 on piano roll and it presses D5 on my VIs
does PT read the device that is the controller and alter the piano roll??
Old 10-27-2015, 11:32 PM
Stig Eliassen's Avatar
Default Re: piano roll / keyboard
Do you have the Triton transposed an octave down?
Do you have MIDI realtime properties enabled?
Old 10-28-2015, 12:33 AM
Been a while but can't you set Middle C to be either C3 or C4 in the MIDI Options as a reference for a MIDI Controller?
Aaron Mulqueen - 001 HD Native
Old 10-28-2015, 03:36 AM
Good point, Filo. That is true.
Old 10-28-2015, 09:10 AM
Thank you! It was set to Alternate pitch in Pro Tools prefs > midi
... set it to Standard and now as expected.
Pro Tools Midi: External Keyboard Input to Piano Roll's Keyboard SupreGlu MIDI 1 05-16-2015 08:26 AM
Piano Roll ? cubs Pro Tools 10 1 01-01-2013 04:49 PM
Can't I just rename the notes on piano roll? dbvoyager Pro Tools 10 2 05-20-2012 08:23 AM
piano roll key size in track n8tron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-16-2010 02:19 PM
Pre roll and Post roll keyboard commands? Bob L 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-30-2007 07:46 AM
