Old 10-13-2015, 02:22 PM
spenedit spenedit is offline
Default Better key command for suspend all groups?
Hi all,
I frequently use the command "suspend all groups" but shift-command-g doesn't exactly fly off the fingertips. Does anyone know an alternate command for this? Maybe use hot keys?
Old 10-14-2015, 06:21 AM
reichman's Avatar
reichman reichman is offline
Default Re: Better key command for suspend all groups?
Keyboard Maestro would let you do something simpler. But if you find yourself doing this with certain groups, change key command focus to the group window and your letter keys will turn groups on and off.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 10-14-2015, 08:13 AM
JFreak's Avatar
JFreak JFreak is online now
I myself find it intuitive, but opinions do vary
Janne
Old 10-15-2015, 12:22 AM
midnightrambler midnightrambler is offline
"Shift-command" is used all over the place, so you'd better get used to it.
Old 10-15-2015, 04:29 AM
Drew Mazurek's Avatar
www.drewmazurek.com
Old 10-15-2015, 08:38 AM
YYR123's Avatar
YYR123 YYR123 is offline
The only thing easier is have a control surface button....
Daniel
Old 10-15-2015, 03:13 PM
Rosco1969 Rosco1969 is offline
If you need to suspend groups in order to move any parameter on it's own.... why not just do exactly the same move you would normally make but.... use "right click" instead of "left click" i.e, the right mouse button instead of the left one. I find that easier. If I understand the question correctly that is.
Rosco
Old 10-15-2015, 10:39 PM
JFreak's Avatar
Yep.
But command-shifting isn't too bad as I usually have two fingers placed close to them anyway. I type with 10 fingers, so even when I use the mouse I have my left hand on keyboard.
Janne
Old 10-16-2015, 12:42 AM
ryanstewartguitar ryanstewartguitar is offline
I type with 11! Thinking about upgrading to 12...
- Ryan Stewart
www.ryanstewartguitar.com
Old 10-16-2015, 05:25 AM
Ben Jenssen's Avatar
Originally Posted by spenedit View Post
Hi all,
I actually never used "suspend all groups", but pressing ctrl lets me adjust faders at least, overriding the group enable. That's on mac, PT10.
Command 8 and groups freakhouse ProControl, Control|24, Command|8 2 07-22-2014 10:09 AM
Way to temporally suspend VCA groups/auto? postprosound Post - Surround - Video 4 02-10-2011 05:14 PM
Suspend Groups command-where is it? hybridd Pro Tools M-Powered (Mac) 1 11-29-2007 04:51 AM
Custom Groups, Can it be don on an 8 Fader D-Command? laki ICON & C|24 2 07-26-2007 04:53 AM
D-Command, delete active groups? Where? rbeggs ICON & C|24 5 02-12-2007 08:07 AM
