Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 01-16-2015, 11:41 AM
quantum7 quantum7 is offline
Default Can the Quartet have 8 outs if the headphone outs are utilized?
I know the specs say 6 outs, but I thought I read somewhere that you could have 8 if the headphone outs are used.
Thanks!
It is better to compose than decompose
Sean Christopher Dockery
www.SeanDockery.com
Sean Christopher - New Age composer
www.SeanChristopher.net
Old 01-20-2015, 05:06 PM
donnydonny's Avatar
donnydonny donnydonny is offline
Default Re: Can the Quartet have 8 outs if the headphone outs are utilized?
Technically, yes you can although the Quartet is designed to be a 6 Output interface with headphone monitoring.
Open Pro Tools IO Control and go to Output Routing. Connect Software Output 7-8 to Phones L/R. In Pro Tools, outputs 7-8 will now go out of the headphone port. You'll just need to balance the headphone volume with the line outputs.
Note that when doing this, you'll lose the ability to monitor through headphones.
Donny
Avid Community Team
Problem with 002 main outs as well as head phone outs? wiseal1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-10-2009 11:36 AM
oo3 console headphone outs? basslik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-20-2009 11:58 PM
All Analog Outs Used-Best D/A option for Headphone Mix? cwholden Pro Tools TDM Systems (Mac) 1 02-12-2008 10:07 AM
Why does the Mbox have two headphone outs if... joesmohello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-08-2003 12:13 AM
Digi Outs work fine---Logic not getting signal to outs Thou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-29-2001 02:52 PM
