Old 01-10-2014, 03:40 PM
Farmer Dave Farmer Dave is offline
Default "Groups" keyboard shortcuts working?
10.8.4
11.1.1.195
2.66 Ghz Quad-Core Intel Xeon
16GB RAM - 1066 MHz DDR3
I've been seeing this on earlier versions of PT11 as well, but curious if I've got something odd going on.
<Command Shift G>
<Command Control G>
These no longer function for me. Using the pull-down does, but I need these key combos to work with any efficiency.
<Command G> DOES still work though.
My Quickeys don't have these keystrokes assigned anywhere, so as far as I can tell PT11 just isn't responding to them.
Anyone else?
Old 01-10-2014, 03:57 PM
bleen bleen is offline
Default Re: "Groups" keyboard shortcuts working?
Command+Shift+G didn't work in PT11 at all for me until I updated the OS to 10.8.5 and PT to 11.1.1.
I see you're still on 10.8.4 - perhaps that's the missing key?
PT Ultimate 2019.10
Avid S3
Mac Pro 6,1 (2.7GHz 12 Core, 32GB RAM, 512GB boot)
macOS 10.14.4
Lynx Aurora(n)/HDX/Sonnet Echo Express III-D
don gunn
Old 01-11-2014, 11:10 AM
Interesting - thanks for the reply.
Old 01-29-2014, 02:51 PM
10.8.4
11.1.2.214
10.3.8.378
Audio Hardware - Coreaudio Aggregate MOTU HD Express & 828mk3 Hybrid
ATI Radeon HD 4870:
NVIDIA GeForce GT 120:
This is still a bit wonky on my system. At times it works correctly, but most of the time not. I've checked all my Quickeys and tested with Quickeys turned OFF as well with the same result.
There is odd behavior in that when I press <Command Shift G>, the "Pro Tools" menu hilites as if some access is being performed there. I did a screen capture to show this in action. Each hilite is it's own keystroke (it doesn't hilite this many times with one attempt - just one hilite per keystroke attempt)
https://dl.dropboxusercontent.com/u/...nd_Shift_G.mov
Very odd.
I haven't done the 10.8.5 OS update. I usually hold off on this kind of thing unless there is concrete proof.
PT10 works correctly.
PT Shortcuts "Editing, Nudging an Trimming" with LMP Numeric Keypad TableTopJoe Pro Tools 10 1 03-17-2015 08:22 AM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Mute / Solo "Shift +" shortcuts don't work kaiserpathos macOS 2 08-14-2011 10:39 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
"Midi hell" or "where did my keyboard go?" John H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-16-2003 03:42 AM
