Old 10-30-2012, 07:31 PM
garnoil garnoil is offline
Default deleting all automation including plugins in a session
It there a short cut to delete all automation (including all the automation written to all the plugins) from a PT session? Highlighting all tracks and doing Control+Delete removes just the volume and pan but I want to delete absolutely all automation especially the plugins.
Old 10-30-2012, 07:54 PM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
Default Re: deleting all automation including plugins in a session
edit/automation/clear all
you've still got the uncertainty of virgin territory so it can be hard to tell where that will leave all the various parameters.
we need to sacrifice the virgin.
Old 11-11-2012, 09:13 AM
TLmix TLmix is offline
Locate to the top of the session. Put all faders in "Write". Option + select Write. Roll the transport and press / click "To End".
TL
Warner Bros. Studios
Old 11-11-2012, 10:24 AM
Control-Delete deletes *all* automation including plug-in automation on every rig I've ever been on.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 11-11-2012, 10:33 PM
ggegan ggegan is offline
I highlight the area I want to clear, or entire session, and do Command/Control-B. If you are looking at the waveform view, then the clips will also be deleted, but if you are looking at any automation view, then all the automation will be deleted, but the clips will be left as-is.
Gary Gegan
Old 11-12-2012, 05:35 AM
I will try this, it sounds like it would work, thanks.
Old 11-12-2012, 10:37 AM
cmaynes's Avatar
cmaynes cmaynes is offline
I think a clear all automation is worthy of a menu command. And it should include ALL automation. and re-zero everything, not just take it to the first existing breakpoint...
charles maynes
sound design and recording for film and media
818 618 0580
Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC.
Old 11-12-2012, 10:49 AM
I'm afraid I don't understand what the issue is; There *is* a Clear All Automation menu command: Edit->"Clear Special"->"All Automation". There's also a keyboard shortcut for it: ctrl-delete. I must do this five times a day in turning a finished song mix into a template for the next piece, and it works just fine.
If you need to first set all parameters to some nominal value, suspend automation, set nominal values, then select a range across tracks and option-command-"/" to write to all enabled, then select across the breakpoints just created and ctrl-delete to get rid of the breakpoints. Takes me about 15 seconds.
Confused,
rich
Old 11-12-2012, 01:02 PM
The Cargo Cult
15 seconds?
you session must look very different to mine.
clear all auto is fine but like I said - who know what values will be left over after doing this.
we do need a way to "zero" all params.
Old 11-12-2012, 01:11 PM
Originally Posted by maggot View Post
15 seconds?
I just place the cursor at a point in the session where all parameters are what I want to call my 'nominal' starting point, then suspend automation, then select range, write to all, then remove breakpoints with ctrl-delete. And yes, takes me about 15 seconds on large 150-track mixes (though of course, size of the session doesn't really matter).
best,
rich
HTML code is On
All plugins missing including audiosuite in pro tools 10.3.7 sinawavak macOS 2 12-02-2013 03:02 PM
Pro Tools 9 Plugins including Compressor Steve369 Windows 10 12-29-2010 06:28 PM
how to process whole regions including handles w/ AS-plugins komokrator Post - Surround - Video 2 12-20-2007 06:16 AM
Replicate A Track Including In/Out, Plugins Etc beau johnson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-28-2005 01:47 PM
lower gain on all tracks including automation rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-08-2004 03:11 PM
