Old 12-20-2010, 02:59 PM
coltonb coltonb is offline
Default Pro tools 9 ASIO problems
So i just bought pro tools 9 and i am having a extremely hard time setting it up, i have the latest ASIO4all drivers set up and everything ready to go and i have read all the troubleshooting threads and avids own troubleshooting but i cant seem to figure it out. I dont have hardware yet but wanted to just run it through my audiocard with asio installed already which i thought was possible with the new version
On the avid site it says their is a drop down menu for the play back engine when you hold down "N" at the startup screen, well i do this their is no option to choose different then ASIO4all which obviously not working and it says i should try pro tools aggregate I/O or however you spell it which is not a option
PLEASEE HELPP!!!!
Old 12-20-2010, 05:21 PM
Default Re: Pro tools 9 ASIO problems
Any responses would be greatly appreciated!!
Old 12-21-2010, 07:57 AM
dougtate dougtate is offline
Not quite the same issue, but when I installed PT9 it 'lost' my 003r and played through my line 6 podxt pro instead. The only interface showing as available on the drop down was the pod. I had to use device manager to update the 003r driver manually to get it to appear.
So I'd check your sound card drivers are up to date / compatable.
Hope this helps
Old 12-21-2010, 09:07 AM
thanks im trying it out right now
Old 12-21-2010, 10:21 AM
weezul weezul is offline
check your ASIO4ALL set up window. it will have probably defaulted to the digital outputs of your onboard sound... change it to the regular outputs and voila, sound
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
[IMG] code is Off
Pro Tools 10.1.2 AND 10.2 ASIO Problems Weiry Windows 8 05-28-2013 01:16 PM
Pro Tools 10 Asio Problems Windows 8 Rackz Windows 2 03-02-2013 12:06 PM
Pro tools 10 and latest 002R asio driver problems scubadrum Windows 6 09-09-2012 02:17 PM
ASIO Problems after installing Pro Tools LE 8? Devils 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 47 01-20-2010 07:51 PM
Asio driver problems with 002 Pro tools 7 with SP2 inka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-03-2007 08:01 PM
