mirrored audio editing?!?
Hi everybody
Does someone know if there's a way to edit all copies of the same audio region (let's say making a fadeout on a sample repeated all along a bass drum track containing the same sample) in one shot? thanks in advance and forgive my poor english :) Matteo |
Re: mirrored audio editing?!?
Any clue?!
Please! |
Make a group of all the tracks you want to give the same treatment. Once you have done your mass edits, disable the group.
Hi albee1952
if i make a group of all samples then make a fadeout on it the fade will disappear once i ungroup i'm doing an house tune, i laid down the same kick sample all along an audio track and now i want to edit that sample... i would like to avoid cleaning all up, do the edit on the first sample then copy it again! on cubase it is called "ghost copy".. thanks for the patience! |
up!
There is a feature called replace region if you have HD or CPTK...
Have you tried using the manual?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Yeah, you need HD or the DV Toolkit for that specific feature. In the meantime you can use the Sound Replacer plugin to replace all the sounds by exporting the newly edited sample as a stereo WAV file, then use Sound Replacer on the old track to "update" the sound (make a new playlist before you do it in case you want to go back).
Tnx guys.. that's what i was searching for :)
Mirrored Output in Core Audio Manager - Not working! | Ash06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 06-10-2010 08:23 AM |
Mirrored MIDI Editing | filosofem | MIDI | 0 | 09-12-2008 04:51 PM |
Mirrored MIDI Editing, what am I missing? | clampire | MIDI | 3 | 03-21-2008 07:05 PM |
Mirrored MIDI Editing is ON by default in 7.3 | jeremyroberts | Pro Tools TDM Systems (Mac) | 3 | 11-30-2007 11:22 PM |
editing audio regions(and the audio file itself) | protuser | Tips & Tricks | 7 | 02-26-2005 09:11 AM |
