#2201
Re: Best Core 2 Series Desktops-Results and Specs
i have the P5Q Pro with the same chipset and it works fine. if you look through this thread youll find a lot of people with the same MOBO/Processors.
Macbook Pro 2.2GHz (late 2011 model), 16GB RAM, OSX 10.7.5 |
#2202
I have the Asus P5Q SE2 w/Intel Core 2 Quad Q9400 - works great.
#2203
Thanks for the replies, very helpful!!! I have a question to you Simon, Are there any issue with your MOBO's on-board firewire?
#2204
no issues with onboard firewire. the only thing i have connected to it is my 002r. works great
#2205
Running the ASUS P5Q SE with the Intel Core 2 Quad 8200 since March. Runs like a dream
Audio Arts for Web & Broadcast since 1999 |
#2206
MSY did you get answer to your question on why only 70 verbs? Curious myself ...
TDub Digi002 R with Command 8 - PTLE 8.03 Intel Quad Q9550 Asus P5Q Pro Win XP 4GB |
#2207
Giving me some trouble!
Duc's! I need some help
my old mo board crapped out on me, so I said screw it with the warranty and bought a new one, ASUS P5Q Pro. Put everything back together in the case, turn it on, computer "sounds" like it's working, but I didn't get the BIOS beep and the monitor won't come on (the old "no input signal received" message on the screen on 2 separate monitors). I've done 2 days worth of plugging, unplugging, checking connections, etc. I am certain that the vid. card works, as I plugged it into my roommates computer to test. A few hours ago I managed to unplug and then replug the Monitor's power and signal cables in the right order and I finally got signal on the screen, but I didn't have my windows CD on hand and shut it down, confident that I had conquered the best. Came back with CD in hand and it was no longer receiving signal... Any help would be greatly appreciated. I've got a really important project that's depending on my computer's ability to turn on! Thanks |
#2208
Re: Giving me some trouble!
Have you considered it might be a bad power supply?
Also make sure you connect the 4 pin (often missed) power plug from the PSU to the motherboard.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#2209
Just bought a brand new PSU as I thought that was the problem to begin with before I realized my mobo was bad, it's working fine... I might try to swap it out though. 4 pin is connected... I must have let all the smoke out. |
#2210
resolved... one of my sticks of RAM is bad... installing drivers now...
hurray |
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
