#2191
Re: Best Core 2 Series Desktops-Results and Specs
Yes.
003r/i7-930/LE 8.0.1 cs2 on xp |
#2192
#2193
Hi Guys, Been a while I have been doing a lot of recording over the last few months and I am still having issues with space bar play/pause...WTF...I am running PT 74.cs4....Just curious if there has been any PT updates that have resolved this. What seems to be the most stable 7.4 version? By the way the the tech support utility dosent work for me it says that I dont have a valid installation of protools installed...BS WTF. The only fix I have have is to close protools go to my computer and delete digidesign database folder on all my drives and restart computer....This is a major pain in the arse.....any help here would be much appreciated.
thanks, Tracy
Asus Sabertooth x79/I7-3930k/32G GSKILL |
#2194
The tech support utility should be loacted in the PT install folder in order to work. Deleting databases in not enough - you need to delete preferances too. I'm using 7.4 cs9 and it stable.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#2195
Need help
I just got a new computer with a p35 intell MB, FSB 1066, 2GB DDR2 800, Q6600 Dual core. I was only able to get 70 DVerbs with the DVerb test. I see much higher results from similar systems, can anyone tell me why that might be? Thanks Martin
#2196
#2197
Re: Need help
what OS are you running? what buffer do you have your system set to?
Macbook Pro 2.2GHz (late 2011 model), 16GB RAM, OSX 10.7.5 |
#2198
Re: Need help
If anyone can think of a reason for his I would greatly appreciate it. This is a computer built specificall for DAW's. It bench tests using sandra as it should with the 6600 core 2 duo benchmark. I need to make a decision very soon, PLEASE HELP ! |
#2199
Re: Need help
I forgot to mention I am usung Protools 8
#2200
By any chance does anyone know if the P45 chipset works fine like the P35, because I'm looking to buy the Asus P5Q Se Plus MOBO along with the NEW Intel Core 2 Quad Q8400 @ 2.66ghz FSB 1333. Thanks!!!
i7 Builds - Specs and Results | mykhal c | Windows | 7144 | 04-15-2024 12:10 PM |
Intel Quad Core vs. i-series | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-23-2010 05:16 AM |
Have a Quad Core (Asus P5K). Use Only One Core Active For Best Results? MIDI Issues. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 08-12-2009 02:24 AM |
are these specs ok? (low budget 2 core) | korkman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-22-2008 02:44 AM |
8 Core Mac Pro, Leopard and Windows results | pasanta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-13-2008 06:51 PM |
