Old 05-03-2007, 02:44 AM
meekz meekz is offline
Default 7.3 installer? Does \"clean uninstal\" delete bombfactory plgs
Problem within the red lines solved.
so i'm havin some problems with LE 7.3.1 (digi002 rack)
and i decided to go through every step in the list in "General Trouble Shooting"
now, one of the suggestions is to uninstall/reinstall pro tools...
since i'm currently running 7.3.1, i have to get the installer for 7.3, uninstal and re-install and then run the 7.3.1 update, right?
the problem is I can't find the 7.3 installer anywhere and the link i got via email when i purchased it has expired. I did not "archive" the installer because in my experience downloading installers have been easy for example for REASON i just go to their page log in and download stuff i'm licenced for.
thanks
By the way, the General Trouble Shooting thread is valuable. it would be more valuable if (i dont know if this possible though) if every step in the list would specify what kind of problems with PT it usually fixes/is associated with.
EDIT: this might be a stupid question but i'm not really that well versed in computer stuff...
When installing something, PACE drivers for example, should I always uninstal previous ones first? or does it do this automatically when installin new ones?
thanks again
Old 05-03-2007, 02:51 AM
Default Re: Where do I download the 7.3 installer?
If you purchased 7.3 from the DigiStore the Installer link will be in your Account Details.
filosofem
Aaron Mulqueen - 001 HD Native
Old 05-03-2007, 02:56 AM
hmmm... i did buy it from there when i looked... didnt see the link but will go back and check now
edit: do i have to register my purchase to see it?
Old 05-03-2007, 03:05 AM
No, because I haven't and it's there. Click View Order Details/Tracking Number and the Receipt page will open containing all 7.3 Installer and Information.
filosofem
Old 05-03-2007, 03:11 AM
Ok, found it
Thanks a bunch!
I was just signed in at digidesign.com, but i had to actually go to digistore (just like you said) and sign in. (although they both use the same log in info and are connected)
that problem solved now.
i'll make changes to my first post, but will leave it there just in case someone else is as dumb as me and tries to search the forum for the same answer
Old 05-03-2007, 03:42 AM
Default Clean Uninstall
"Clean Uninstal
Removes all Pro Tools files, including system files, Digidesign plug-ins, and MIDI patch names"
does "Digidesign plugins" include the Digi/Bombfactory ones?
hmm... if i'm doing this i should probably backup my I/O setups too? is it as simple as draggin the i/o setup file from a folder to a new destination or do i have to open PT and go to the i/o set up and just save to my back-up destination?
Old 05-03-2007, 08:23 PM
Default Re: Clean Uninstall
Ummm... this question I asked before and Rail considered them as third party and should be uninstalled.
Yeah, I surpose.
Don't know about you, but I use Export and Import I/O Settings.
filosofem
9.0.6 Full Installer for Clean Install - misprint on AVID page? smpkeys Pro Tools 9 3 06-30-2012 10:12 PM
Installer of Clean Sweep Old Version needed. tilman Post - Surround - Video 1 05-11-2011 05:03 AM
When You Do a Clean Uninstall, Does it Delete Your Plug-ins folder? David Penick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-28-2008 12:54 PM
cannot uninstal Protools 7.4 dadking 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-10-2008 05:30 PM
HOW DO I UNINSTAL PRO TOOLS? emil123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-26-2007 08:16 AM
