Waves Vocal Bundle 1.1 - PT7 compato - available
I just heard from Waves that Vocal Bundle 1.1 is now available for downloading... PT7 compato, says tech support.
I just installed it, and we'll see... I'll report back if I encounter any problems.
--Jeremy |
Re: Waves Vocal Bundle 1.1 - PT7 compato - available
I see waveshell 5.3 and 5.0.3 are now available for 7 to replace 5.2 and 5.0.1 We offer this compatibility update to all Waves users covered by Waves Update Plan. This update enables you to use Waves V5 Plug-ins under Pro Tools 7 with enhanced functionality. • Enhanced efficiency resulting in increased RTAS plug-in counts. • Automatic conversion of HTDM inserts to RTAS inserts. • Support for 1 or 2 RTAS processors on Dual CPU computers. Chris
Well, it works great now. 1 or 2 processors. Even works with relatively low buffer settings.
Unfortunately, there's still one design flaw that may keep me from using it: You can't have the conductor track enabled with any tempo changes. Yeah... almost makes it unuseable for most of the work I do... there's ALWAYS a conductor track of some kind... if I'm lucky, there are no vocals that need tuning over a tempo change... but if I'm not lucky, the workaround: 1. Bounce a music referrence, on a "sample" based track... make sure vocal track is on a sample based track; 2. Turn off conductor track 3. Work with Tune until satisfied. 4. Bounce tuned vocal to sample based track 5. disable source vocal track 6. Turn on conductor 7. Mute/disable reference track. But what if I'm not ready to bounce the vocal? What if I just want to see if it's possible? I sent an email to Waves... Am I the only one who uses a conductor track? Is it just me? Am I over-reacting here? Is there a better workaround?
--Jeremy |
PS - Waves support emailed me and advised me that they are working on a solution so that the conductor track and tempo changes are no longer an issue. In their words, "We are aware and motivated to make a fix for this issue a.s.a.p."
This sounds promising! At least that doesn't sound like a permanent, engineering brick wall. I have confidence we'll see this fixed soon. For everyone who beats up Waves -- I gotta say their tech support is professional, fast response time (less than 4 hours, typically), and makes me feel I am getting value for the cost of the product(s). Maybe, sometimes, you get what you pay for?
--Jeremy |
Waves Platinum Bundle Users, Can you get rid of Vocal Bundl? | Dizzi45Z | Pro Tools TDM Systems (Mac) | 2 | 03-26-2008 03:16 PM |
How do I remove Waves Vocal Bundle? | Bryan Cook | Pro Tools TDM Systems (Mac) | 5 | 04-02-2007 11:27 AM |
Waves Vocal Bundle | boostedrsx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-10-2007 08:01 PM |
Using Waves Vocal Bundle plugs to zap mouth clicks | David MacNeill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 05-16-2006 10:13 AM |
Waves TUNE & vocal bundle | jeremyroberts | Pro Tools TDM Systems (Mac) | 54 | 11-14-2005 09:12 AM |
