  #141
Old 03-12-2024, 08:40 AM
SoapOperaGuy SoapOperaGuy is offline
Default Re: PT 2024.3 | Released
Ok, so, every time I open a new session it beach balls and freezes. Doesn't matter if I click from open recent, or close session and select other sessions from my files. Have to restart pro tools. Then the new session will open first try after that.
Edit update: This only happens when you open a different session while the current session is open. If you close current session THEN open session it doesn't beach ball and crash.
Mac Studio M1Ultra 14.1.2
  #142
Old 03-12-2024, 09:31 AM
marianna's Avatar
marianna marianna is offline
Originally Posted by datkings View Post
Marianna from Avid noticed a few of us in this forum thread who are having this issue and created a support case for us (thanks Marianna). An Avid Technical Support rep reached out to me for some additional information which I provided yesterday. It appears this was just a bug and the M-Audio controller was not intentionally removed. Avid are looking into it for us…
Hey everyone that commented on the m-audio driver removal..... here is why this was done and what was discovered during testing. My apologies on behalf of Avid for not communicating this was going to happen prior and not adding to the Release Notes for 2024.3 either. Notice was sent to the product team to not do that in the future .....
During testing for the latest version of Pro Tools, Avid software development teams found that the old M-Audio keyboard driver (originally created to support 2 M-Audio keyboard controllers that have been out of support for over 10 years) was causing unwanted interactions with other control protocols such as EUCON and HUI. It became necessary to remove the driver in Pro Tools 2024.3 to preserve performance, stability, and functionality for EUCON and HUI-based controllers.
In the meantime, we recommend that users of third-party hardware that relied on the deprecated M-Audio driver to follow the manufacturer’s instructions on how to setup their device with Pro Tools software.
So with the introduction of MIDI FX support and expanded MIDI signal flow, Pro Tools 2024.3 focuses on MIDI workflow and demonstrates our commitment to ongoing enhancements of the MIDI capabilities in Pro Tools. We are also working closely with the MIDI association to embrace the latest standards and expand functionality in the near future.
Thanks....
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
  #143
Old 03-12-2024, 11:49 AM
daeron80 daeron80 is offline
Originally Posted by nimsat View Post
Recording to an audio track without first selecting a time region to record to produces a wav file that is not recognised as an audio file by other apps.
That means the files are not being closed - it's as if it's in record ready. Raw audio, basically. I bet RX would see it. Audacity probably would. Should be an easy bug to track down and fix.
David J. Finnamore
  #144
Old 03-12-2024, 12:48 PM
nimsat nimsat is offline
Yes, RX does see them as does the mac finder. Still shouldn't be happening though.
I've opened a ticket so will see what transpires.
  #145
Old 03-12-2024, 12:53 PM
tope d's Avatar
tope d tope d is offline
Hi there,
I've started a support case for you under case number 04771221.
You'll be assisted via Email.
Thanks
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
  #146
Old 03-12-2024, 01:13 PM
JoelG's Avatar
JoelG JoelG is offline
Does "in the mean time" mean the M-Audio driver will be coming back?
Thanks,
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
  #147
Old 03-13-2024, 01:56 PM
subwoof subwoof is offline
M-Audio Keyboard option in Peripherals MIDI is not there in 2024.3. How can I work around this?
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
  #148
Old 03-13-2024, 02:37 PM
marianna's Avatar
Thanks,
Joel
Hi Joel,
No, it will not be coming back to PT. Whatever device/product you are using - you need to contact the manufacturer for their guidance. The only product that this driver was designed for by M-Audio/Avid were the 2 M-Audio keyboards which are 10+ years old now.......
Sorry....
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
  #149
marianna's Avatar
See above response to Joel......
Marianna
Marianna Montague
[email protected]
AOL IM avidmarianna
  #150
Old 03-13-2024, 02:48 PM
TimNielsen TimNielsen is offline
This is absolutely pathetic behavior from Avid, but not sure why anyone would expect any less. Zero communication, in an instant broke the entire working paradigm for a ton of us who use either V-Control or Mulligan. Sad and just WRONG. Avid, you could EASILY just FIX the damn driver right?
What I would like to see in ProTools in 2024 ! stevegalante Pro Tools 125 03-25-2024 12:37 AM
Runnind PT 10 and 003 Factory with NEW 2024 Mac PRSWILL macOS 20 01-18-2024 07:08 AM
