Old 12-30-2019, 04:05 PM
mbcn mbcn is offline
Default 96 I/O not showing in hardware
Hello from Barcelona, Spain!
Thanks everyone for any help.
I bought an A/D card for my I/O96. After installing it and restarting my system, the 96 is not showing up in my PT HD 10.3.10 hardware page any more.
After disconnecting the new card, the hardware appears again.
I tried deleting PT and AVID prefs but that doesn´t seem to be the problem.
I also have a I/O 192 as primary, working fine.
The card works fine, I connected it with the main card´s cable.
And all is ok. Only when the three cards are plugged there is this problem.
Any ideas of what can be happening??
Is it possible that the 96 needs also a D/A Output card?
I read that the 96 can work even with one only card, so I don´t know...
Thanks very much for your help!
Old 12-31-2019, 02:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: I/O96 not showing in hardware.
I don’t think the i/o expansion was ever developed for the 96! So your expansion card won’t work in the 96, only in the 192.
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-31-2019, 05:00 AM
Originally Posted by crizdee View Post
Chris
Thanks Chris, but it´s exactly the same that comes with the 96! The one with the 8 DAC TRS jack inputs! It should work!
I tried it with the 192 and it does not work.
Old 12-31-2019, 09:34 AM
There are many old threads on DUC pointing out the 96 IO is not expandable. All findable with google search.
Old 12-31-2019, 10:23 AM
I looked up a lot, probably wrongly.
Thanks for the (bad) news...
Is it possible to make the 8 input card work with a 192?
I will google that too in the meanwhile.
Thanks Darryl.
Old 12-31-2019, 10:32 AM
Originally Posted by Southsidemusic View Post
I can say Yes to that so you can stop google and get the 192 working
Happy 2020 then, however I tried installing the card in the 192 and didnt work.
Message was "cant find a primary interface attachaed...".
Probably wrong slot?
I checked the manual though...
Couldn´t make it happen.
Thanks
Old 12-31-2019, 10:34 AM
Southsidemusic's Avatar
Thanks
Have you tried both Digilink connections and made 100% certain the cable is OK?
Does this card only work with the non 192i/o version maybe? Anyone knows this?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-31-2019, 10:54 AM
Yes. I plug the A/D card, 192 not showing.
After unplugging, 192 showing again.
Double checked the card. Also working.
I am talking about this card...
Old 12-31-2019, 11:22 AM
The cards are not compatible. Pretty sure also been discussed on DUC in the past :-O And findable with a google search
.... my advice pick up a used 192 or HD IO.
Old 01-01-2020, 06:59 AM
Default Re: 96 I/O not showing in hardware
Well, thanks to everyone... I will try to solve it some other way.
Just needed one extra analog input... I will figure out.
Happy 2020!
Analog inputs 9-16 showing up in Hardware, not in I/O? voidmix Pro Tools HDX & HD Native Systems (Mac) 8 09-25-2012 07:06 PM
11R not showing up under Hardware Setup NoiseRoom Eleven Rack 5 05-29-2011 03:43 PM
mbox 2 pro box hardware not showing lechszcz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-28-2008 03:26 AM
mbox2 usb hardware not showing up when launched??? touringmbox2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-20-2006 02:01 PM
Hardware not showing on PT boot talco Pro Tools TDM Systems (Mac) 1 06-06-2002 11:10 AM
