Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-16-2019, 10:49 PM
littletrainrec littletrainrec is offline
Default MIDI Device Problems on PT 2019
I'll start by apologizing if this seems like a rudimentary question. I'm technically inept enough where this has stumped me.
For many years, I've recorded with PT 6.x, 7.x, and LE, an Mbox2 interface, and a MIDI keyboard (a Casio WK-3000). I recently (finally) got a new laptop with Windows 10 and some processing power, so I subscribed to PT 2019.
It's great with mics and DI instruments, but I can't get PT 2019 to recognize the Mbox2 as a MIDI input device, and thus can't get any virtual instruments to work. I run MIDI-OX and it tests fine. I've tried reinstalling drivers to no avail. I've watched more YouTube tutorials than I'd care to admit. I plug the Mbox back into my old computer/PT LE, and it works fine.
I'm hoping that those are more knowledgeable about these things than me (which is probably all of you!) can offer any suggestions. I realize that my interface is ancient at this point, so this budget conscious musician is hoping it's not a compatibility issue.
A very sincere thank you for any thoughts.
Old 09-18-2019, 12:08 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: MIDI Device Problems on PT 2019
Hi, so it isn't showing up under Setup-MIDI-MIDI Input Devices? Have you checked the Instrument options In/Out MIDI channels on the MIDI/Instrument channel in the Mix Window?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 09-18-2019, 04:41 AM
musicman691 musicman691 is online now
And in the PT prefs window in the MIDI section make sure that 'use first selected track' is checked.
I know the op mentioned that he checked with MIDI-OX and things were okay and that's an excellent bit of troubleshooting. Still I would make sure that all Windows power saving measures are turned off in Windows Control Panel. By default the USB ports are set to turn off after a certain amount of time.
Jack
QAPLA!
Old 09-18-2019, 06:32 PM
Thank you for the reply! Right, the Mbox2 isn't showing up under Setup>MIDI>MIDI Input Devices. (It does on my old version of PT LE). I messed around with the I/O on the channel, but nothing seems to work.
I thought maybe it did have something to do with the USB ports on the laptop, but I would think that it wouldn't power my Mbox if so.
Old 09-18-2019, 08:49 PM
cwsand's Avatar
I used to have this problem in Windows though I don't recall exactly what fixed it. Have you tried trashing preferences? You might also try uninstallling the keyboard or interface from Device Manager and performing a clean uninstall/reinstall of Pro Tools. Then reinstall the keyboard/interface drivers.
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2019.6
Old 09-26-2019, 08:16 AM
Thank you, cwsand and musicman691, for your input!
I have finally resolved the issue - I had, at one point, tried plugging my MIDI keyboard directly into the computer and setting it up separately as a MIDI device. I removed that, plugged back into my Mbox, and it worked like a charm.
Pro Tools 2019 CPU Spike Problems robo92la Pro Tools 12 2 07-22-2019 10:46 AM
2019.5 Ultimate on Mac not seeing iLok license (and other possible problems) Pete Gates Pro Tools 2019 21 05-19-2019 10:40 AM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 03:50 PM
Problems connecting midi device Ravenfrost 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-01-2007 02:00 PM
New midi device problems ruinerr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-07-2005 09:11 PM
