Old 09-04-2019, 07:17 AM
quadraphonics quadraphonics is offline
Default EUCON command to toggle Dynamic Plug In Processing
All,
Is there a Eucon command on the S Series boards to toggle Dynamic Plug In Processing On/Off?
Thanks,
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 09-04-2019, 11:14 AM
creativecontrol's Avatar
Default Re: EUCON command to toggle Dynamic Plug In Processing
There is not. Just out of curiosity, why would you need to keep toggling that feature on and off?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-06-2019, 11:22 AM
It has been recommended to us by Dolby to turn this feature off when using the Dolby ATMOS local renderer send/return setup - especially when making DAPFs and ADM wavs.
Randall
Jeff
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 09-09-2019, 07:09 PM
Understood.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-18-2019, 12:23 AM
kosmokrator kosmokrator is offline
Randall
Hi Randall,
that's interesting. Can you elaborate a bit on why? What was the issue that you were running into?
Asking because I'm just right now sitting in front of a Atmos (local renderer) session. With Dynamic plugin-processing on...
Old 09-18-2019, 06:34 AM
I presume he is referencing the following knowledge base article or the direct recommendation of a Dolby engineer:
https://developerkb.dolby.com/suppor...return-plugins
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-18-2019, 02:04 PM
I was told by Dolby to turn it off. We were seeing a delay between the beds and the objects playing back at slightly different times when making DAFPs.
Originally Posted by kosmokrator View Post
Hi Randall,
Randall Smith
Audio Editor/Mixer
Denver, CO
Old 09-19-2019, 12:51 AM
AH, so that's the culprit!
Had this issue too...
Old 10-29-2019, 05:48 AM
This should no longer be necessary to toggle with the new workflows enabled in Pro Tools Ultimate paired with the new v 3.3 Dolby Atmos Renderer using Dolby Audio Bridge as a Playback Engine.
http://www.avidblogs.com/pro-tools-2019-fall/
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Dynamic Plug-in Processing jkess Pro Tools 12 6 09-04-2019 12:35 PM
Dynamic Plug In Processing - 9173 etc. T-Low Pro Tools 2018 1 01-09-2019 01:22 AM
HEAT + Dynamic Plug in Processing in 12.6 T-Low Pro Tools 12 0 09-29-2016 12:44 PM
Dynamic Plug-in Processing Question quantise Pro Tools 11 1 03-13-2014 09:05 AM
Is Dynamic Plug-in Processing messing up some VI's Touchwood Studios Pro Tools 11 2 11-19-2013 02:09 PM
