Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 01-22-2020, 09:54 PM
SomeOtherGuy SomeOtherGuy is offline
Default Re: Can't get MTRX Dante card to work...
Sorry for being dense but not sure where patch point in Dante Controller is...
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 01-22-2020, 09:56 PM
Do you mean this:
File Type: png Screen Shot 2020-01-22 at 9.55.25 PM.png (85.2 KB, 0 views)
Old 01-22-2020, 09:57 PM
creativecontrol's Avatar
In order to route the output of your Mac applications and System Sounds to the Dante hardware input on the MTRX you need to patch your active Dante Virtual Soundcard into your MTRX using Audinate's Dante Controller software which can be found here:
https://www.audinate.com/products/so...nte-controller
Transmitters show up on the upper right - DVS (your machine name) needs to be patched to the lower left MTRX 1-2 inputs.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Here's the Mac:
File Type: png Screen Shot 2020-01-22 at 9.56.35 PM.png (30.2 KB, 0 views)
Old 01-22-2020, 09:59 PM
Jeff
Ah, I didn't realize I needed that. Thank you! Will download and install now...
  #16
Old 01-22-2020, 10:10 PM
I'm here, but not understanding transmitters show up on the upper right - DVS (your machine name) needs to be patched to the lower left MTRX 1-2 inputs.
File Type: jpg Screen Shot 2020-01-22 at 10.08.54 PM.jpg (39.6 KB, 0 views)
  #17
Old 01-22-2020, 10:16 PM
You need to collapse the "Gary's-Mac-Pro" under Receivers on the bottom left. You need to find your MTRX BrooklynII card which, from your other images, is currently labeled Penta-197344. Expand that and make a patch from the top - "Gary's-Mac-Pro" as a Transmitter to "Penta-197344" as a receiver for channels 1 and 2. Make sure your MTRX Dante and DVS are on the same subnet.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #18
Old 01-22-2020, 10:22 PM
Thanks, but I'm not sure where to look for Penta-197344. I don't see it anywhere in the Dante Controller panel.
Here it is collapsed:
File Type: jpg Screen Shot 2020-01-22 at 10.21.46 PM.jpg (28.8 KB, 0 views)
  #19
Old 01-22-2020, 10:26 PM
In the control panel for Dante Virtual Soundcard you can specify the NIC that you want the Dante streams to use. You need to correlate your Dante Virtual Sound Card NIC with the NIC that you are using for your MTRX Dante option card. That is, they both need to be on the same network. Best practices would be to have a router that supplies addresses to all devices on the network. You can check out the network settings of the MTRX including the Dante option card by going to Settings > Device List > (IP Address of unit) Right Click > Network Settings.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #20
Old 01-22-2020, 10:27 PM
I just changed the interface to en1 instead of en0 and now it shows up...
MTRX-> HDX or MTRX->Dante ArmyofLight Pro Tools | MTRX & MTRX Studio 34 04-08-2021 04:51 PM
Avid MTRX with Dante SRC Question apasco Pro Tools | MTRX & MTRX Studio 3 01-15-2020 06:24 PM
MTRX hookup question, Dante vs Digilink SomeOtherGuy Pro Tools | MTRX & MTRX Studio 26 01-03-2019 11:29 AM
MTRX Dante latency stuck at 1ms LukeHoward Pro Tools | MTRX & MTRX Studio 1 02-19-2018 11:13 PM
MTRX Sync Dante and Video laki Pro Tools | MTRX & MTRX Studio 10 12-05-2017 02:26 AM
