Old 08-03-2019, 02:04 AM
Led Led is offline
Default Windows 10 system restore deleted my ptx files!
I was having issues with my SSL converters today and tried a bunch of stuff and it all got so messy I thought I'd just do a system restore to get around it. My last restore point was about 2 weeks old, I restored to it, and afterwards, every ptx file for any session I'd done after that restore point was gone. For me that's about 20 sessions. All the rest of the folders for each session were still the same, just the session file - gone!
I cried a little, then undid the restore and they were back, but thought I'd post here just so others know to be cautious. It's not supposed to touch your data files, but it appears it doesn't like ptx extension files.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 08-03-2019, 04:50 AM
StillHollow StillHollow is offline
Default Re: Windows 10 system restore deleted my ptx files!
Thanks for letting us know. And yet more justification for daily and automatic backups of our sessions sessions to external drives.
Really glad you got your stuff back Led.
Old 08-03-2019, 09:58 AM
The Weed's Avatar
The Weed The Weed is offline
I never trust System Restore. It's actually turned off permanently. I image my OS and Session drives nightly with Macrium Reflect. There are other imaging/clone programs, I just like MR.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-03-2019, 12:17 PM
TOM@METRO's Avatar
I use "Acronis True Image", never system restore.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 08-04-2019, 07:41 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
I have System Restore turned off, even on my everyday, non-ProTools computers. I also use Acronis True Image.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 08-07-2019, 07:08 PM
What drive were your ptx files on? If they are on drive C: then that's probably not a surprise(and they should be on a separate recording drive). If they already were, then I am as confused as you On the subject of backups, I am also pretty OCD on that. I used Acronis for years(several versions) but recently gave up on it because it will not clone correctly. Now I am using Backupper for cloning and imaging. Macrium Reflect is another option from drive imaging/cloning on Windows
Old 08-07-2019, 09:36 PM
sw rec sw rec is offline
Another vote for a separate, dedicated recording drive. Yes, recording to the system drive might work, but do you really want to take that chance, when a 1tb drive can be had for under 100 bucks? What’s all your hard work worth when it disappears?
Old 08-08-2019, 01:25 AM
Led Led is offline
Yeah both good points, I normally use a different drive for my sessions, but it had some issues and I got lazy while waiting for a new M.2 to arrive to take it's place. I was using the program SSD then backing up after each day. I'd been so flat out I had gotten sloppy with backups for a couple of weeks, which ironically is precisely when you need to stay on top of it the most.
New drive is in and all is back to normal, I am now the only weak link in the chain..
Andy Evans
www.mud.net.au
Old 08-08-2019, 11:46 AM
ChuckS ChuckS is offline
Just a quick question for the OP - Where was the folder located for your sessions that the PTX files went missing - root, User, Documents, OneDrive? I used System Restore before and didn't have this issue with sessions stored in folders in the Documents folder. It was a while ago - some things may have changed.
PT 2019.12 DP 10.11 VEP 7.x Komplete Audio6 HP Envy 8G i7 Quad Laptop Win10 (x64 2004)
PT 2019.12 DP 10.11 VEP 7.x 828mkII ADA8200 MTP-AV 2011 Mac Mini i7 Quad High Sierra.6
Old 08-08-2019, 03:52 PM
Led Led is offline
In the documents folder...
Andy Evans
www.mud.net.au
Restore dae files? jockoapa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-08-2008 09:37 AM
System Restore, Win XP Pro Jay Terrien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-06-2008 02:42 PM
XP System Restore Tim1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-06-2006 07:28 PM
system restore in windows xp jon sutton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-13-2004 03:46 PM
My Audio files were deleted!!! What software to buy to restore the files.... lucio matarazzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-22-2000 07:45 PM
