Old 01-23-2012, 08:22 PM
adune adune is offline
Default How can I get Firmware 1.03 to install in my 11 rack???
I need help!
I cannot load firmware 1.03 into my Windows 7 64 bit machine running pro tools 9.03.
I keep getting a message that the drivers are not installed but I use the 11 rack all the time in pro tools 9 with it working fine with firmware 1.01. I'm trying to update it to 1.03, so I click the install button anyway and it still will not work to matter what I do.
very frustrating. anybody have this issue?
Old 01-24-2012, 02:09 AM
gregklau gregklau is offline
Default Re: How can I get Firmware 1.03 to install in my 11 rack???
Have the exact same problem. I tried updating on 3 different systems and made sure IE 9 wasn't installed. I've posted on a few different forums asking for help and have gotten no response. Haven't found a solution yet.
Old 01-24-2012, 01:10 PM
Benoni's Avatar
Benoni Benoni is offline
For some reason it seems that 1.0.3 won't install on systems that have the latest Eleven Rack driver. I am guessing you both have driver version 1.0.11 installed.
Try uninstalling the 1.0.11 driver and install the older 1.0.8 driver. Then try to load Firmware 1.0.3 - Note that on Windows 7 64 bit there is a problem with the interface not correctly reporting the presence of the 11R driver. The Install/Continue button will be "grayed out", click it anyway and it should install.
After you get 1.0.3 installed you can uninstall the 1.0.8 driver and re-install the 1.0.11 driver so you are up-to-date driver wise.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-24-2012, 05:47 PM
I'll have to give this a try. Where would I find the 1.0.8 drivers? Can't seem to locate them, only version 1.0.11. Thanks.
Old 01-24-2012, 08:47 PM
Benoni's Avatar
They are buried on the Avid site some where. At least they use to be, they may have been taken down. I'll look around, you do the same, and if you haven't found them by tomorrow, I believe I still have them on a back up, so I can upload them somewhere for you if you can't find them anywhere.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-24-2012, 09:20 PM
Benoni's Avatar
Here is the 1.0.8 driver for Windows for the Eleven Rack.
http://akmedia.digidesign.com/suppor...iver_62994.zip <----------- Direct Download
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 01-25-2012, 07:29 PM
I am going to have to try it, gregklau did it work for you?
Old 01-26-2012, 08:08 AM
junkgear's Avatar
junkgear junkgear is online now
You are a genius Benoni. Thank you, thank you, thank you!!!!!
I too could not load firmware version 1.0.3 on my ER, tried everything and was about to give up. Then I saw this post and figured what the heck, I'll give it a try.
So, I uninstalled 1.0.11, then loaded the 1.0.8 driver on my system and the firmware updated on the first shot
Just a note, I did this on my 32 bit Win7 system. I don't know if it works for 64 bit variations.
Old 01-26-2012, 03:34 PM
bassmanjazz bassmanjazz is offline
Benoi is a great asset to the forum and I think we would all be lost without him!
Old 01-26-2012, 04:16 PM
I just got around to trying the update on my Windows 7-64 bit machine again using Benoni's method and it worked like a charm. Thanks a ton Benoni for the tip and the link for the old driver version. I can't believe the hoops that you have to go through to install software and updates from Avid. BTW, I also had to uninstall IE 9. But in the end, all is good.
Firmware install issues SimonBarSinister Eleven Rack 6 03-22-2011 07:32 PM
HELP! LE 7.4 and 002 Rack issue after new Rack firmware upgrade monolithsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-13-2010 10:29 AM
ProTools LE 8.0 install / 002 Rack Firmware Upgrade magicbus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2009 12:36 PM
Hard reset or re-install firmware for the X-Mon? fantom27 ICON & C|24 0 12-25-2005 08:01 PM
002 rack firmware update killed my rack and OS X bandgear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-01-2003 08:25 PM
