Old 06-23-2003, 04:04 PM
sselrahc sselrahc is offline
Default import audio is greyed out on the file menu
does anyone know hot to activate the import audio selection on the file menu. When is select file it shows the import audio to track as greyed out and it cannot be selected.
Thanks
Old 06-23-2003, 04:11 PM
8mmOverdose 8mmOverdose is offline
Default Re: import audio is greyed out on the file menu
Thanks
<font size="2" face="Verdana, Arial">did you create a new session first?
Old 06-23-2003, 04:25 PM
Roy Howell Roy Howell is offline
Are your tracks filled up? (it does that if they are)...if so, now's the time to decide what you can do without and delete, or you can move some similar audio from 2 tracks to one, then delete the blank one to free up a track.
If that's not the case, I'm not sure what it could be.
rh music
Old 06-23-2003, 04:42 PM
Roy u hit it right on the head. It looks like pro-tools wants to create the tracks itself and won't use tracks that already exsist. Thanks
Old 06-23-2003, 04:47 PM
... or just use Import Audio in the region list menu (Ctrl+Shift+I).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Consolidate audio - Greyed out in Edit menu Richard901 Pro Tools 9 10 01-31-2016 03:42 AM
Region Groups-->Clip Groups Import File Menu Not working minister Pro Tools 11 0 01-06-2014 11:23 AM
Import audio from CD greyed out? mhender General Discussion 0 08-23-2013 03:42 PM
9.0.5 audio import menu missing characters sidi1 macOS 2 09-13-2011 04:53 AM
Why does the 'import audio' menu take sooo long! mishmash Pro Tools TDM Systems (Mac) 24 01-25-2003 05:36 AM
