Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-31-2020, 05:57 PM
JimmyD150155 JimmyD150155 is offline
Default Protools 2020 Mac Catalina Just Crashes
Hi just downloaded the 2020 Protools and opened to select song menu, when I select a song previously made Protools just crashes without any message, tried this with several songs and the same thing.
It does open a new song
Mac-Mini 2018
3.2gHz 6-core intel core i7
64gb 2667 MHz DDR4
Intel UHD Graphics 630 1536 MB
Help appreciated, I went back to 2019 -12 and works just fine again,!!!!
Thanks
Old 03-31-2020, 07:49 PM
Default Re: Protools 2020 Mac Catalina Just Crashes
Just to be proactive I reinstalled 2020 again and exactly the same problem. I opened a new track just to look at the new features, added a Click Track and no matter what I tried NO CLICK just the track.
Back to 2019 - 12 again until these bugs are fixed
Old 03-31-2020, 10:41 PM
JFreak's Avatar
JFreak JFreak is offline
Kumusta.
I do not see this here on macOS 10.15.4 Catalina. What OS are you running?
Janne
Old 04-01-2020, 02:47 AM
Hi I using 10.15.3 i will update and revert back to you if improvement
Thanks
Old 04-01-2020, 03:18 AM
JFreak's Avatar
No problem, just let me know how it goes.
Btw. my wife is from Bohol, right next to you
Janne
Old 04-01-2020, 07:22 AM
Hi after trying quite a few things including the update which did not help I discovered that by removing all 3rd party plugins it worked ok. I then started to add back in the plugins and eventually I found the one that was causing the problem so just left it out and has been working ok for the last two hours as I test.
Thanks for the help, this has happened many times before as I have read and is a good check should you get the crash situation.
Old 04-01-2020, 07:23 AM
JFreak's Avatar
Glad to hear you found your problem plugin. Hopefully you get an update soon
Janne
wow hope you get to visit here sometimes, would be great to meet you. I have a house here in Cebu also.
Old 04-01-2020, 09:22 AM
nedorama nedorama is offline
for the rest of us, what plugin was causing the problem?
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Old 04-02-2020, 09:43 AM
Waves Vocal Rider was my problem
2020.3 is out innesireinar Pro Tools 2020 114 04-09-2020 08:55 AM
2020.3 Mac 5,1 stargazer Pro Tools 2020 25 04-03-2020 02:54 PM
Protools 19.12 catalina 10.15.3 NI Maschine mk3 frabo Pro Tools 2019 1 03-17-2020 10:57 AM
Protools 2019.12 and Catalina 10.15.2 combo jeam25 macOS 20 02-10-2020 12:03 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
