Confused with freeze/bounce of VI-tracks
Hi
sorry for the newbie-question - I did some research beforehand, but not to my satisfaction. Just starting with VIs. I was under the impression, that due to the nature of VIs and their use of samples, there is no such thing as track freeze and offline-bouncing and that the workflow needed to be to record each VI-track to a separate stereo track in real-time, and these new tracks then can be bounced to a stereo-file. I was really surprised, that freeze and offline-bounce did work (using VSL and NI Kontakt). But since I only was experimenting, I did not fully test things, just a 6-track minimalistic arrangement. So: does freeze/bounce really work (flawlessly?), or did I encounter a happy circumstance, where it worked and the normal workflow should be to record to individual tracks and work from there? Thanks! |
Re: Confused with freeze/bounce of VI-tracks
It works, as it should. And you just proved it. There is no reason freeze should not work, some code runs saves a copy of the audio and replays that instead of reprocessing it each time.
Audio Drop-out During Offline Bounce and Freeze Tracks | JKHansen | macOS | 0 | 09-28-2017 07:06 AM |
No Track Freeze or Bounce Individual Tracks | playthemdrums | Pro Tools 9 | 11 | 03-29-2011 12:51 PM |
MIDI Tracks Versus Instrument Tracks. VERY Confused. | Rick540 | MIDI | 8 | 12-04-2008 11:04 AM |
bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE | plenky | Pro Tools TDM Systems (Mac) | 2 | 09-01-2000 10:06 AM |
bounce in Logic4.5=OK/bounce inPT5.0.1=FREEZE | plenky | Pro Tools TDM Systems (Mac) | 0 | 08-31-2000 04:01 PM |
